How to Clear Cloudy Pool Water: Complete Fix Guide 2024
Jeff U.
Weekend Pool Warrior
Is my cloudy pool water safe for kids to swim in?
Our pool turned into a cloudy mess ever since the kids' party last weekend, and now I'm worried it's not safe for them to swim. They keep asking to get in, but I don't want to risk their health if there's something wrong with the water quality.
What's the proper way to clear up cloudy pool water and make it safe again? I want to make sure I'm doing everything right - testing chemicals, shocking, filtering, whatever it takes. How do I know when the water is actually clear and safe enough for the kids to swim again?
Clear cloudy pool water by testing and balancing chemicals first, then shock with liquid chlorine to 2-3x your stabilizer level, run the filter 24/7, and backwash frequently until water clears completely.
Understanding What Causes Cloudy Water
Before jumping into solutions, it's crucial to understand that cloudy water stems from microscopic particles suspended in your pool. These particles are too small for your filter to catch initially, creating that milky, hazy appearance. Common causes include:
Complete Water Chemistry Testing
Start with a comprehensive water test using a reliable test kit like the Taylor K-2006C. You need accurate readings for:
Warning: Never add chemicals without knowing your current levels. This can worsen the problem or create unsafe swimming conditions.
Step-by-Step Clearing Process
Phase 1: Chemical Balance Correction
  1. Adjust pH first: If pH is above 7.6, add muriatic acid. Use 1 quart per 10,000 gallons to lower pH by 0.2 points. Add acid to deep end with pump running.
  2. Lower total alkalinity if needed: High TA causes pH drift and reduces chlorine effectiveness. Use muriatic acid method - add acid, let pH drop to 7.0, then aerate to raise pH back to 7.4-7.6.
  3. Address calcium hardness: If over 400 ppm, partially drain and refill. If under 150 ppm, add calcium chloride at 1.25 lbs per 10,000 gallons to raise 10 ppm.
Phase 2: Shock Treatment
  1. Calculate shock level: Use liquid chlorine to reach shock level based on your CYA. For example, with 50 ppm CYA, target around 20 ppm FC for shock treatment.
  2. Add liquid chlorine: Use 1 gallon of 12.5% sodium hypochlorite per 10,000 gallons to raise FC by 10 ppm. If using 10% solution, use 1.56 gallons per 10,000 gallons. Add chlorine at dusk or night to prevent sun degradation.
  3. Maintain shock level: Test FC every 2-4 hours and add more chlorine to maintain target level. This is the SLAM (Shock Level And Maintain) method.
Phase 3: Filtration and Circulation
  1. Run filter continuously: Keep your pump running 24/7 during treatment. This is not the time to save on electricity.
  2. Clean filter frequently: For sand filters, backwash when pressure rises 8-10 psi above clean pressure. For cartridge filters, rinse every 2-3 days or when pressure rises 8-10 psi above clean pressure.
  3. Use clarifier if needed: Add clarifier according to label directions to help bind microscopic particles. Avoid flocculant unless you can vacuum to waste.
Advanced Troubleshooting
If Water Doesn't Clear in 48 Hours
Special Situations
Green/cloudy water: This indicates algae presence. Follow SLAM method continuously until you can clearly see the bottom and main drain and FC loss overnight is 1 ppm or less.
White/gray cloudiness: Often indicates calcium precipitation from high pH. Lower pH immediately and increase circulation.
Post-rain cloudiness: Usually environmental contamination. Shock treat and run filter continuously for 24-48 hours.
Prevention Strategies
Preventing cloudy water is easier than treating it:
Remember, clearing cloudy water requires patience and consistent treatment. Test water chemistry every 4-6 hours during treatment, maintain proper chlorine levels, and keep that filter running until your pool returns to crystal clarity.
pool test kit liquid chlorine muriatic acid pool brush test strips or digital tester
Tags: #cloudy water #pool chemistry #chlorine shock #SLAM method #filter maintenance
