How to Fix Cloudy Pool Water: Complete Step-by-Step Guide
Todd Y.
Is cloudy pool water safe for kids? How do I clear it up?
Staring at my neighbor's crystal-clear pool while mine's been cloudy for days has me worried about letting my kids swim. I can't see the bottom clearly anymore and I'm not sure if it's safe or what's causing it.
I have a test kit but I'm not entirely sure what to do with the results or how to fix this properly. Should I be shocking the pool? How long does it usually take to clear up? I just want to make sure the water is completely safe before the kids get back in there.
Fix cloudy pool water by testing and balancing chemistry first, then shock with liquid chlorine to at least 10-12 ppm, run the filter continuously, and maintain shock level until water clears completely.
Step-by-Step Guide to Clear Cloudy Water
  1. Test Your Water Chemistry Completely
    Use a reliable test kit like the Taylor K-2006C to measure all parameters: Free Chlorine (FC), pH, Total Alkalinity (TA), Calcium Hardness (CH), and Cyanuric Acid (CYA). Don't rely on test strips for accurate readings. Record all numbers before proceeding - this baseline is crucial for determining the correct treatment approach.
  2. Balance pH and Total Alkalinity First
    If pH is above 7.8, add muriatic acid to bring it down to 7.4-7.6. High pH reduces chlorine effectiveness and contributes to cloudiness. For every 0.2 pH reduction needed, add approximately 6-8 fl oz of muriatic acid per 10,000 gallons. If TA is above 120 ppm, lower it using muriatic acid as well. Target 80-100 ppm for regular pools, 60-80 ppm for salt water generators.
  3. Determine Your Shock Level
    Based on your CYA reading, calculate the proper shock level using the FC/CYA relationship. For CYA of 30-50 ppm, shock to 12-20 ppm FC. For higher CYA levels, you'll need proportionally more chlorine. This is critical - under-shocking won't clear the cloudiness effectively.
  4. Add Liquid Chlorine (Not Granular Shock)
    Test and confirm pH is balanced before proceeding to chlorine addition. Use liquid chlorine (sodium hypochlorite) rather than calcium hypochlorite shock, which can contribute to cloudiness. Add approximately 1 gallon of 12.5% liquid chlorine per 10,000 gallons to raise FC by 13-15 ppm. Pour slowly around the pool perimeter with the pump running. Never add all chemicals at once.
  5. Run Your Filter System Continuously
    Set your pump to run 24/7 until the water clears completely. This is not the time to worry about electricity costs. Clean or backwash your filter before starting, and be prepared to clean it multiple times during the clearing process as it captures the particles causing cloudiness.
  6. Test FC Levels Every 8-12 Hours
    Maintain your shock level by testing and adding more liquid chlorine as needed. FC will drop as it works to clear the water. Don't let it fall below your target shock level, or the process will stall. This maintenance phase is crucial for success.
  7. Brush Pool Surfaces Daily
    Brush walls, steps, and floor twice daily to help circulation and prevent particles from settling. Pay special attention to areas with poor circulation like steps, corners, and behind ladders. This mechanical action helps the chemical treatment work more effectively.
  8. Continue Until Crystal Clear
    Don't stop treatment when water looks "better" - continue until it's completely crystal clear. This usually takes 3-7 days depending on how cloudy the water was initially. Only when FC holds steady overnight without dropping significantly is the process complete.
  9. Resume Normal Maintenance
    Once clear, reduce FC to normal operating levels based on your CYA reading (typically 3-5 ppm for CYA of 30-50 ppm). Resume regular testing schedule and normal pump runtime. Consider what caused the cloudiness to prevent recurrence.
Common Causes of Cloudy Water
Safety Warnings and Important Notes
Warning: Always add chemicals separately and never mix them directly. Wait at least 30 minutes between different chemical additions. Wear safety equipment including goggles and gloves when handling pool chemicals, especially muriatic acid.
Avoid using clarifiers or flocculants as a shortcut - they often make problems worse by clogging filters. The SLAM (Shock Level And Maintain) method is the most reliable approach for clearing cloudy water permanently.
Contact a pool professional if cloudiness persists after following these steps for more than a week, if you're uncomfortable handling chemicals, or if you suspect equipment failure. Recurring cloudiness often indicates underlying equipment or plumbing issues that require professional diagnosis.
Taylor K-2006C test kit liquid chlorine muriatic acid pool brush measuring cups
Tags: #cloudy water #pool shock #SLAM method #water chemistry #pool maintenance
