How Long Do Pool Filter Cartridges Last? Complete Guide
When should I replace my cartridge filters? They're expensive!
Woke up to cloudy pool water again and realized I'm already on my third set of cartridge filters since moving into this rental two months ago! I've been replacing mine every month because that's what the pool store told me, but honestly I have no idea if that's actually necessary or if they're just trying to sell me more stuff.
My pool gets used pretty regularly by the family, and I try to keep up with cleaning the cartridges when they look dirty. But I'm never sure if I should keep cleaning them or just bite the bullet and buy new ones. How do I know when they're actually done for? There has to be some way to tell when cleaning isn't cutting it anymore, right?
Pool filter cartridges typically last 2-4 weeks with proper maintenance, but actual lifespan depends on bather load, water chemistry balance, and cleaning frequency. Cartridges should be replaced when cleaning no longer restores proper flow.
Factors That Affect Cartridge Lifespan
Pool Usage and Bather Load
The number of swimmers directly impacts how quickly your cartridges become dirty. Each swimmer introduces oils, lotions, dead skin, and other contaminants that clog filter media. High-traffic pools during summer months will require more frequent cartridge changes than pools used occasionally.
Water Chemistry Balance
Proper water chemistry significantly extends cartridge life. When your pH stays between 7.4-7.6 and total alkalinity remains at 80-120 ppm, your sanitizer works efficiently, reducing the burden on your filter. Poor water balance leads to algae growth, cloudiness, and rapid cartridge clogging.
Free chlorine levels should match your CYA (stabilizer) levels according to the FC/CYA chart, which shows the proper relationship between Free Chlorine and Cyanuric Acid levels for effective sanitization. Target 30-50 ppm CYA for outdoor pools, but indoor pools should maintain 0-30 ppm CYA since UV protection isn't needed. When chlorine levels drop too low, organic contamination increases dramatically.
Environmental Factors
Pools surrounded by trees, frequent dust storms, or heavy pollen seasons will clog cartridges faster. Windblown debris, leaves, and organic matter all contribute to faster cartridge deterioration. Consider your local environment when planning replacement schedules.
Signs Your Cartridges Need Replacement
- Reduced water flow: Even after thorough cleaning, flow remains restricted
- Shortened cleaning intervals: Cartridges get dirty within days instead of weeks
- Visible wear: Pleats are fraying, filter media is deteriorated, or end caps are damaged
- Persistent cloudiness: Water remains hazy despite proper chemistry
- Pressure gauge readings: High pressure returns quickly after cleaning
- Discoloration: Permanent staining that won't clean out
Maximizing Cartridge Lifespan
Proper Cleaning Technique
Clean cartridges every 1-2 weeks by rinsing with a garden hose from top to bottom, spreading pleats to reach all surfaces. For deeper cleaning, soak overnight in a cartridge cleaner solution or rotate between two sets of cartridges, allowing thorough drying between uses.
Maintain Excellent Water Chemistry
Test your water 2-3 times weekly using a quality test kit like the Taylor K-2006C. Keep pH at 7.4-7.6, maintain appropriate free chlorine levels based on your CYA, and ensure calcium hardness stays at 250-350 ppm for plaster pools (lower for vinyl/fiberglass).
If you encounter algae problems, perform a SLAM (Shock Level And Maintain) process using liquid chlorine, maintaining shock level FC until you pass the overnight chlorine loss test. This prevents organic buildup that rapidly clogs cartridges.
Pre-Filtration Strategies
Use skimmer socks or leaf traps to catch larger debris before it reaches your cartridges. Regular skimming and vacuuming also reduces the filtration load. Consider running your pump longer during heavy use periods to maintain water clarity.
Replacement Schedules by Pool Type
Residential Pools (Light Use)
Family pools with 2-4 regular swimmers can typically run cartridges for 3-4 weeks with proper maintenance and balanced chemistry. Keep a spare set for rotation cleaning.
High-Traffic Pools
Pools with frequent parties, many children, or daily heavy use may need weekly cartridge changes during peak season. The increased organic load overwhelms filter capacity quickly.
Salt Water Pools
Salt water generators maintain more consistent chlorine levels, often extending cartridge life. However, the slightly higher pH tendency requires regular monitoring and adjustment to prevent scale buildup on cartridge fibers.
Cost-Effective Cartridge Management
Purchase cartridges in bulk during off-season sales, and always keep spare sets on hand. Quality cartridges from reputable manufacturers like Unicel, Pleatco, or Filbur typically last longer than generic alternatives, making them more economical long-term.
Consider upgrading to cartridges with antimicrobial treatments or larger surface areas if your current cartridges consistently fall short of expected lifespan.
Warning: If you're replacing cartridges weekly despite good water chemistry and low usage, you may have underlying circulation issues, inadequate filtration capacity, or water balance problems requiring professional diagnosis.
Persistent problems with short cartridge life often indicate the need for system upgrades, additional filtration equipment, or addressing water source issues that continuous contamination.
