How DE Pool Filters Work: Complete Guide to Diatomaceous Earth
Jim Y.
Hot Tub Owner
Are DE filters really safe and effective for family pools?
Three days after backwashing my DE filter, it's creating this weird cloudy ring around the return jets that wasn't there before. My kids spend hours in the pool every day during summer, and water quality is my top priority.
I've heard that DE filters use some kind of powder coating, but I'm not clear on the actual filtration process. How fine are the particles that get filtered out? I want to ensure we're getting the cleanest, safest water possible for my children to swim in.
DE (diatomaceous earth) filters work by coating filter grids with fine DE powder that traps particles as small as 2-5 microns. Water flows through the DE coating, which captures contaminants while allowing clean water to pass through.
How DE Pool Filters Function
Good news: understanding and maintaining your DE pool filter is solidly DIY territory—no expensive service calls needed to keep this powerhouse filtration system running like new. They work by using a fine, white powder made from fossilized remains of diatoms - microscopic algae with hard shells. This powder coats specially designed filter grids and creates an incredibly fine filtration medium that can trap particles as small as 2-5 microns, making your pool water crystal clear.
The DE Filtration Process
The filtration process begins when your pool pump pulls water from the skimmers and main drain. This water enters the DE filter tank, which contains 8-12 curved filter grids (depending on filter size) arranged in a circular pattern around a central manifold.
Before the filter can work effectively, you must "precoat" the grids with DE powder. When you add DE powder to your skimmer with the pump running, the powder is drawn into the filter tank and coats each grid evenly. This DE coating becomes your actual filter medium - not the grids themselves.
As water flows through the DE-coated grids, the microscopic DE particles trap dirt, oils, dead algae, bacteria, and other contaminants. The clean water passes through the grids, flows up through the central manifold, and returns to your pool through the return jets.
Why DE Filters Are So Effective
Diatomaceous earth consists of tiny, porous particles with irregular shapes and sharp edges. These characteristics make DE extremely effective at filtration:
DE Filter Components and Their Roles
Filter Grids
Filter grids are fabric-covered frames that provide structure for the DE coating. Made from polypropylene or nylon fabric stretched over plastic or metal frames, these grids must be kept clean and in good repair. Damaged grids will allow DE powder to escape into your pool.
Manifold Assembly
The central manifold collects filtered water from all grids and channels it back to the pool. Each grid connects to the manifold via a tube or standpipe. If these connections are loose, unfiltered water can bypass the DE coating.
Air Relief Valve
Located on top of the filter tank, this valve releases trapped air that can prevent proper water flow and DE distribution.
DE Filter Maintenance Cycle
Understanding the maintenance cycle helps you keep your DE filter operating at peak efficiency:
Normal Operation
During normal operation, your DE filter pressure will gradually increase as the DE coating traps debris. Most filters operate efficiently between 10-25 PSI, depending on your specific system.
Backwashing
When pressure rises 8-10 PSI above the starting pressure, it's time to backwash. This process reverses water flow through the filter, washing away the dirty DE coating and trapped debris. After backwashing, you must add fresh DE powder to recoat the grids.
Deep Cleaning
Every 6-8 backwash cycles, or at least twice per season, you should disassemble the filter and clean the grids manually. This removes oils and fine particles that backwashing cannot eliminate.
Proper DE Dosing
Using the correct amount of DE powder is crucial for optimal filtration:
Your filter manual will specify the exact square footage of filter area and DE requirements for your specific model.
Warning: Always use pool-grade DE powder, never DE intended for pest control or other uses. When handling DE powder, wear a dust mask and avoid breathing the fine particles. While food-grade DE is generally safe, prolonged inhalation of any fine dust can irritate respiratory systems. Ensure your DE powder is amorphous (non-crystalline) silica, as crystalline silica poses serious health risks. Dispose of spent DE properly - never dump it down drains or storm sewers as it can harm aquatic life and clog plumbing.
If DE powder appears in your pool, check for torn filter grids or loose manifold connections. If your filter pressure rises quickly after backwashing, your grids likely need manual cleaning to remove embedded oils and fine debris.
Other common problems include: clogged grids that prevent proper DE coating distribution, using incorrect DE amounts (too little reduces filtration, too much can damage grids), multiport valve issues that prevent proper backwashing, and air locks that reduce water flow through the system.
DE filters require more hands-on maintenance than cartridge or sand filters, but they reward you with superior water clarity that makes the extra effort worthwhile.
DE powder pressure gauge reading filter manual
Tags: #DE filter #diatomaceous earth #filter operation #pool filtration #filter maintenance
