Does Lowe's Have Pool Chemicals? Complete Shopping Guide
Todd O.
Where can I buy pool chemicals? Lowe's have what I need?
This summer my neighbor's pool stays crystal-clear while I'm constantly driving to multiple stores hunting down chlorine, pH adjusters, and shock treatments.
Does Lowe's carry all the pool chemicals I need? I'd prefer to shop somewhere I trust that has a good selection so I can get everything in one trip. Can I order online if they don't have something in stock? I just want to make sure the water is safe for my children before they jump in.
Yes, Lowe's carries a wide selection of pool chemicals including chlorine, pH adjusters, shock treatments, and algaecides both in-store and online year-round.
Step-by-Step Guide to Shopping for Pool Chemicals at Lowe's
  1. Check availability before visiting: Use Lowe's website or call your local store to verify specific products are in stock. Pool chemical availability can vary seasonally, with peak selection from March through September.
  2. Locate the pool section: Pool chemicals are typically found in the seasonal/outdoor section of the store, usually near patio furniture and grills. During peak season, there's often a dedicated pool chemical aisle.
  3. Identify your pool's needs first: Before shopping, test your pool water using a reliable test kit like the Taylor K-2006C. Know your current pH, total alkalinity, free chlorine, and cyanuric acid levels to purchase the right chemicals.
  4. Choose liquid chlorine for regular sanitizing: Lowe's stocks liquid chlorine (sodium hypochlorite) in 1-gallon jugs, typically 10-12.5% strength. This is the most cost-effective and pure form of chlorine for daily sanitizing and SLAM treatments.
  5. Select pH adjusters based on your needs: Purchase muriatic acid (31.45% hydrochloric acid) to lower pH, or sodium carbonate (soda ash) to raise pH. Lowe's carries both in various sizes.
  6. Get alkalinity increaser if needed: Look for sodium bicarbonate products to raise total alkalinity. Target range is 80-120 ppm for most pools, or 60-80 ppm for salt water generator pools.
  7. Consider calcium hardness increaser: If you have a plaster pool, you'll need calcium chloride to maintain 250-350 ppm calcium hardness. Vinyl and fiberglass pools need lower levels.
  8. Purchase stabilizer for outdoor pools: Buy cyanuric acid (stabilizer) to protect chlorine from UV degradation. Target 30-50 ppm for regular pools, or 70-80 ppm for salt water generator pools.
  9. Compare prices and sizes: Calculate the cost per pound or gallon to find the best value. Larger containers are usually more economical if you have storage space.
  10. Check expiration dates: Ensure chemicals haven't been sitting on shelves too long. Liquid chlorine loses potency over time, especially in heat.
What Pool Chemicals You'll Find at Lowe's
Sanitizers
Lowe's stocks various chlorine forms including liquid chlorine (best for regular use), calcium hypochlorite (cal-hypo), and trichlor tablets. For pool clarity and algae issues, stick with liquid chlorine as it doesn't add unwanted byproducts like stabilizer or calcium.
pH and Alkalinity Adjusters
You'll find muriatic acid for lowering pH and total alkalinity, sodium carbonate for raising pH, and sodium bicarbonate for raising alkalinity. These are essential for maintaining proper water balance.
Specialty Chemicals
Lowe's carries algaecides, clarifiers, enzyme products, and metal sequestrants. However, proper chlorination using the SLAM method (Shock Level And Maintain) is more effective than algaecides for treating green water.
Pricing and Value Considerations
Lowe's pool chemical prices are generally competitive with other big-box retailers but may be higher than pool specialty stores or online bulk purchases. Liquid chlorine typically costs $3-5 per gallon. Watch for seasonal sales, especially end-of-summer clearances.
Money-saving tip: Many pool stores and Walmart often have better prices on liquid chlorine. Compare costs per gallon of available chlorine, not just the sticker price.
Online vs. In-Store Shopping
Lowe's offers both in-store pickup and delivery for pool chemicals. Heavy items like liquid chlorine or large bags of shock are convenient to order online for pickup. However, hazardous materials restrictions may limit shipping options for some chemicals.
Safety Considerations When Shopping
Important safety reminders:
Alternatives to Consider
While Lowe's is convenient, consider these alternatives for potentially better value:
For the most effective pool maintenance, focus on liquid chlorine, muriatic acid, and a quality test kit rather than expensive specialty products. The Trouble Free Pool method emphasizes simple, effective chemicals that actually work.
pool test kit vehicle for transport
Tags: #lowes #pool chemicals #shopping guide #liquid chlorine #pH adjusters
