What licenses do I need to start a pool cleaning business?
Do I need some kind of special license just to clean pools? What about when I'm adding chemicals or fixing pumps and filters? I've heard different things from different people and I'm getting conflicting information about business permits too. Really hoping someone can break down what's actually required because I'm ready to make this career change happen!
Most states don't require a license for basic pool cleaning services, but commercial pool service businesses may need business licenses or permits. Chemical handling and pool maintenance involving equipment repairs often have additional requirements. The article provides a detailed breakdown of state-specific requirements and the importance of professional certifications for pool service providers.
Basic Pool Cleaning vs. Licensed Services
The licensing requirements depend heavily on what type of pool cleaning you're doing:
- Basic cleaning services: Skimming, vacuuming, brushing, and emptying baskets typically don't require special licenses
- Chemical balancing: Adding chlorine, adjusting pH, and basic water chemistry usually falls under general pool cleaning
- Equipment repair/installation: Often requires contractor licenses or specialized certifications
- Commercial pool maintenance: May require health department certifications
State-by-State Variations
Requirements differ dramatically across states:
States with Minimal Requirements
Many states like Texas, Arizona, and Nevada don't require specific pool cleaning licenses for residential services. You'll still need:
- General business license
- Liability insurance
- Workers' compensation (if you have employees)
- Sales tax permit
States with Stricter Requirements
California, Florida, and Louisiana have more comprehensive requirements:
- California: Requires a C-61/D-35 Pool & Spa Maintenance contractor's license for service/repair contracts of $1,000 or more (threshold raised from $500 in 2025)
- Florida: Commercial pool operators need certification from the Department of Health
- Louisiana: Commercial/public pools must be overseen by a CPO-certified operator; the state does not mandate a certification exam for residential pool-cleaning technicians
When You Need Certifications
Chemical Handling Certifications
While basic chlorine addition rarely requires certification, some situations do:
- Using commercial-grade chemicals
- Handling acids like muriatic acid in large quantities
- Performing SLAMShock Level And Maintain — raise free chlorine to a target based on your CYA and hold it there until the algae is gone. It's a process, not a one-time dose. the SLAM walkthrough → (Shock Level And Maintain) procedures for algae elimination — see our all-in-one pool calculator for the right shock level
- Managing high CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → (cyanuric acid) levels that exceed safe limits
The Pool & Hot Tub Alliance (PHTA) — formed in 2019 from the merger of NSPF and APSP — offers the Certified Pool Operator (CPO) certification, which many commercial facilities require.
Equipment Work Licensing
If your pool cleaning service includes equipment maintenance, you may need:
- Electrical contractor license for pump/light work
- Plumbing license for pipe repairs
- General contractor license for structural repairs
- HVAC certification for pool heater service
Commercial vs. Residential Requirements
Residential Pool Cleaning
Most homeowner pool cleaning falls under minimal regulation. You can typically:
- Test and balance water chemistry using standard test kits
- Add liquid chlorine to maintain free chlorine at the right level for your CYA (typically 4-8 ppm for a stabilized outdoor pool, or 6-9 ppm for a salt pool with CYA 70-80)
- Adjust pH to 7.4-7.6 range using muriatic acid or sodium carbonate
- Maintain total alkalinity at 80-120 ppm
- Clean filters and empty skimmer baskets
Commercial Pool Requirements
Public pools, hotels, and community facilities have stricter oversight:
- Health department permits and inspections
- Certified pool operator on staff or contract
- Detailed chemical logs and testing records
- Emergency response procedures
- Specialized insurance coverage
Getting Started Without a License
If you're starting a pool cleaning business in an area without licensing requirements:
- Register your business with local authorities
- Obtain general liability insurance (minimum $1 million recommended)
- Get proper equipment: test kits, vacuum systems, chemical storage
- Learn water chemistry principles, including FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → relationships — our all-in-one pool calculator estimates the free chlorine target for your CYA
- Understand when to perform SLAM procedures for algae issues
- Master pH and alkalinity adjustments
Professional Development
Even without mandatory licensing, professional certifications benefit your business:
Recommended Certifications
- CPO (Certified Pool Operator): Comprehensive water chemistry and equipment training
- PHTA certifications: Various specialized programs for pool professionals
- Manufacturer training: Equipment-specific certifications from companies like Pentair or Hayward
Continuing Education
Stay current with:
- New chemical treatment methods
- Environmental regulations
- Safety protocols
- Equipment technology advances
Safety and Liability Considerations
Important: Even without licensing requirements, you're still liable for:
- Chemical burns from improper handling
- Equipment damage from incorrect procedures
- Water quality issues leading to illness
- Property damage from chemical spills
Always maintain detailed service records, use proper chemical storage, and follow manufacturer guidelines for all products.
Next Steps
Before starting any pool cleaning business:
- Contact your local business licensing office
- Check with your state's health department
- Consult with insurance agents about coverage requirements
- Consider professional training even if not required
- Network with established pool professionals in your area
