Winterizing Winterizing — Do I Need Pool Antifreeze? Complete Winterizing Guide
Sarah H.
Sarah H.
DIY Pool Enthusiast
When do I actually need pool antifreeze for winter?
According to my old above-ground pool routine I never needed antifreeze, but now I'm questioning everything with this inground setup. My neighbor swears by it but another friend says it's totally unnecessary. I live in an area where we definitely get below freezing temps, but I'm not sure if my equipment can be completely drained or not.
What are the situations where pool antifreeze is actually needed? And if I do need it, does it matter what type I buy? Don't want to mess this up and end up with burst pipes come spring!
Pool antifreeze is necessary if your pool equipment and plumbing lines can't be completely drained or if temperatures regularly drop below freezing. Use only propylene glycol-based pool antifreeze, never automotive antifreeze.
Do people actually use antifreeze in their pool? Yes—but almost never in the water itself. In cold climates, pool owners pour non-toxic RV/marine antifreeze (propylene glycol) into the plumbing lines, skimmer, and pump when closing the pool for winter, so any water that can’t be blown out won’t freeze and crack the pipes. You never add it to the pool water, and you never use automotive antifreeze. Many pros skip it and simply blow the lines out instead—so whether you need it comes down to your climate and how you winterize.
When You Need Pool Antifreeze
In a freezing climate, water left sitting in your pool’s pipes can freeze, expand, and crack them—an expensive repair that winterizing is meant to prevent. Whether you need antifreeze depends on your climate, pool type, and how completely you can blow out the lines.
If you're in a region with occasional freezing temperatures or have plumbing lines that retain water after blowing out, pool antifreeze provides critical freeze protection. However, if you can achieve complete drainage through proper blow-out procedures and live in a milder climate, you may not need it.
Understanding Pool Antifreeze Types
Never use automotive antifreeze in your pool system. Automotive antifreeze contains ethylene glycol, which is toxic and will damage your pool equipment and contaminate your water.
Most pool/RV antifreeze is propylene-glycol based, which is non-toxic and safe for pool plumbing. Note that some "RV & marine" products (such as the Arctic Ban and Prime Guard types) are an ethyl-alcohol/propylene-glycol blend rather than pure PG — still safe for pool lines, but check the label. Popular brands include:
  • Prime Guard -50°F RV & Marine Antifreeze (ethyl-alcohol/propylene-glycol blend; pool-safe)
  • In The Swim Pool Antifreeze
  • SPLASH RV & Marine -50°F Antifreeze (propylene glycol; rated for pools and spas)
  • Camco Arctic Ban RV & Marine Antifreeze (ethyl-alcohol/propylene-glycol blend; rated for pool plumbing to -50°F)
These products typically provide freeze protection when used undiluted - check manufacturer specifications for exact protection temperatures as they vary by brand.
Where to Use Pool Antifreeze
Skimmer Lines
Skimmer lines are the most common place where water gets trapped after winterization. Even after blowing out lines, some water often remains in the curved sections of piping. Remove skimmer baskets, add 1-2 quarts of pool antifreeze to each skimmer, then plug the skimmer bottom after the antifreeze has flowed into the lines.
Return Lines
If your return lines weren't completely cleared during blow-out, add antifreeze through the return fittings. Typically, 1 quart per return line provides adequate protection for residential pools.
Main Drain Lines
Deep main drain lines often retain water even after professional blow-outs. If you suspect water remains in these lines, add antifreeze through the main drain or via the pump housing.
Equipment Lines
Heater lines, chlorinator lines, and other auxiliary equipment connections may need antifreeze if they can't be completely drained. Check manufacturer recommendations for specific equipment.
How Much Antifreeze to Use
The amount depends on your specific situation:
  • Skimmer lines: 1-2 quarts per skimmer
  • Return lines: 1 quart per return
  • Main drains: 2-4 quarts depending on depth and line length
  • Spa lines: 1-2 quarts for typical residential spas
For very cold climates (below -10°F regularly), consider using 1.5 times these amounts. In moderate freeze zones (20-32°F), you can often use slightly less.
Proper Application Method
  1. Complete your blow-out first: Use an air compressor or shop vacuum to remove as much water as possible from all lines
  2. Install winter plugs: Install skimmer and return line plugs only after adding antifreeze, so the antifreeze can flow into the lines first
  3. Pour antifreeze slowly: Add antifreeze directly into skimmers and return fittings, allowing it to flow into the lines
  4. Check for leaks: Ensure antifreeze isn't leaking from loose plugs or fittings
  5. Label your work: Keep records of where you added antifreeze for spring opening reference
Regional Considerations
Northern Climates
If you live in areas with sustained freezing temperatures (Zone 6 and colder), pool antifreeze is typically necessary. Even professional-grade blow-outs rarely remove 100% of water from complex plumbing systems.
Moderate Climates
In zones 7-8 where freezing is occasional, you might skip antifreeze if you achieve excellent drainage. However, the cost of antifreeze (typically $25-120 total, depending on pool size) is minimal compared to potential freeze damage repairs.
Mild Climates
Zones 9-10 rarely need pool antifreeze unless you experience unusual cold snaps. Focus on proper water level management instead.
Alternatives to Antifreeze
Some pool owners use alternative freeze protection methods:
  • Freeze protection devices: Automatic systems that circulate water when temperatures drop
  • Partial winterization: Running equipment periodically during winter
  • Pool covers with air pillows: Reducing freeze expansion pressure on pool walls
These methods work in some situations but require active monitoring and may increase utility costs.
Spring Opening Considerations
Pool antifreeze doesn't need to be removed before opening your pool. Propylene glycol will dilute harmlessly when you refill your pool. However, if you added significant amounts, you might notice slightly slippery water initially, which will normalize after a few days of circulation and filtration.
Test and balance your water chemistry normally, as antifreeze doesn't significantly impact pH, alkalinity, or sanitizer effectiveness at the diluted levels present after refilling.
Cost-Benefit Analysis
Pool antifreeze typically costs $8-15 per gallon, and most residential pools need 3-8 gallons total. Compare this $25-120 investment against potential freeze damage repairs:
  • Cracked skimmer: $200-500 repair
  • Burst pipes: $300-800 repair
  • Equipment damage: $500-2000+ replacement
The insurance policy that antifreeze provides makes it worthwhile for most pool owners in freeze-prone areas.
Tags: #antifreeze #freeze protection #winter closing #plumbing protection
