Can Salt Water Pools Cause Diarrhea? Health Risks Explained
Stephanie P.
Salt water pool making people sick - is it the chlorine levels?
This might sound ridiculous, but why do people keep getting stomach issues and diarrhea after swimming in our salt water pool? I know salt pools are supposed to be "cleaner" but clearly something's not right here.
I'm thinking maybe our salt cell isn't doing its job properly? Like, could low chlorine levels in a salt pool actually cause diarrhea and stuff? And if so, what should I be testing for to make sure this doesn't happen again? Really don't want to be known as the neighbor with the sketchy pool!
Salt water pools can cause diarrhea if the salt cell isn't producing adequate chlorine or if the water is contaminated with harmful bacteria. The solution is maintaining proper free chlorine levels of 1-3 ppm and balanced pH.
Why Salt Water Pools Can Cause Digestive Issues
Many pool owners mistakenly believe salt water pools are "chemical-free," but they still rely on chlorine for sanitization. The salt chlorine generator converts salt into hypochlorous acid (the same sanitizer as liquid chlorine). When this system fails or operates inefficiently, dangerous pathogens can multiply rapidly.
Common Contamination Sources
Testing and Diagnosing the Problem
Start by testing your water chemistry immediately using a reliable test kit like the Taylor K-2006C. Focus on these critical parameters:
Free Chlorine Levels
Your free chlorine should read 1-3 ppm consistently. Salt water pools often struggle with chlorine production, especially when:
pH and Total Alkalinity Balance
Maintain pH at 7.4-7.6 and total alkalinity at 80-120 ppm for salt water pools. High pH (above 7.8) dramatically reduces chlorine effectiveness, even when readings appear adequate.
Immediate Solutions to Prevent Illness
Emergency Sanitization Protocol
If you suspect contamination or have inadequate chlorine levels:
  1. Shock the pool immediately: Add liquid chlorine to raise free chlorine to 10 ppm
  2. Run filtration continuously: Keep your pump running 24 hours until levels stabilize
  3. Test every 2-4 hours: Monitor free chlorine and add more liquid chlorine as needed
  4. Maintain shock level: Keep FC at 10 ppm for at least 8 hours with clear water
  5. Clean the salt cell: Remove calcium buildup that reduces efficiency
Adjusting Salt Chlorine Generator Output
Increase your generator's output percentage gradually while monitoring chlorine production. Adjust generator output based on chlorine demand - start at 50% and increase gradually while monitoring chlorine levels. If you're running at 100% and still can't maintain 1-3 ppm FC, your cell may need replacement or professional inspection.
Long-Term Prevention Strategies
Regular Maintenance Schedule
Weekly tasks:
Monthly tasks:
Cyanuric Acid Management
Salt water pools should maintain CYA levels at 30-50 ppm for optimal chlorine protection. However, excessive CYA (above 100 ppm) creates "chlorine lock," where sanitizer becomes ineffective. If CYA is too high, partially drain and refill your pool.
Contact a pool professional immediately if:
Health Precautions
While addressing water chemistry issues, follow these safety guidelines:
Remember that properly maintained salt water pools are generally safer than traditional chlorine pools when chemistry is balanced correctly. The key is consistent monitoring and prompt action when problems arise. Your health depends on maintaining that delicate balance between salt cell efficiency, proper circulation, and adequate sanitizer levels.
Taylor K-2006C test kit liquid chlorine muriatic acid salt cell cleaning stand safety goggles rubber gloves
Tags: #salt water pool health #pool diarrhea #salt chlorine generator #pool contamination #water chemistry
