Do You Backwash Pool Cartridge Filters? Complete Answer
Can I backwash my cartridge filter or do I need to replace it?
Nobody warned me about this musty, chlorine-soaked smell coming from my cartridge filters that my pool store insists I need to replace every few months.
They're telling me I need to replace them, but I'm wondering if there's a way to backwash these things like you can with sand filters? I've got a standard cartridge filter system and I'm looking for ways to maintain it myself without constantly buying new filters.
Is backwashing even possible with cartridge filters, or am I stuck with the expensive replacement cycle? I'd love to find some DIY solutions to keep these things running longer without breaking the bank on new cartridges every season.
No, you cannot backwash cartridge filters - they must be manually cleaned or replaced. Cartridge filters work differently than sand or DE filters and require physical cleaning with water and filter cleaner.
First, Let's Diagnose Why This Question Comes Up
Many pool owners coming from sand or DE filter systems naturally assume all pool filters can be backwashed. This confusion is understandable since backwashing is such a common maintenance procedure for other filter types. However, cartridge filters operate on a completely different principle that makes backwashing impossible and unnecessary.
How Cartridge Filters Work Differently
Cartridge filters use pleated polyester fabric or paper-like material to trap debris and contaminants. The pleated design creates a large surface area in a compact space, capturing particles as small as 10-15 microns. Unlike sand filters that rely on a bed of sand media or DE filters that use diatomaceous earth powder, cartridge filters are self-contained units with no loose filtration media to redistribute through backwashing.
Proper Cartridge Filter Maintenance Solutions
Method 1: Basic Rinse Cleaning
- Turn off the pool pump and ensure the system is completely shut down before opening the filter housing
- Remove the filter housing lid by turning counterclockwise or releasing the clamp mechanism
- Lift out the cartridge filter(s) - most systems have 1-4 cartridges depending on size
- Use a garden hose with a spray nozzle to rinse between each pleat from top to bottom
- Rotate the cartridge as you spray to ensure all surfaces are cleaned
- Pay special attention to heavily soiled areas, spraying at a 45-degree angle into the pleats
- Rinse until water runs clear from the cartridge
- Reinstall the clean cartridge and replace the housing lid
- Turn the pump back on and check for proper flow
Method 2: Deep Cleaning with Filter Cleaner
Every 4-6 cleanings, cartridges need a deep clean to remove oils, lotions, and mineral buildup that simple rinsing can't eliminate.
- Follow steps 1-3 from the basic rinse method
- Prepare a filter cleaning solution in a large bucket - use products like Natural Chemistry Filter Perfect or Leisure Time Filter Clean
- Submerge the cartridge completely in the cleaning solution
- Allow to soak for 8-24 hours depending on soil level and manufacturer recommendations
- After soaking, rinse thoroughly with clean water until no cleaner residue remains
- Warning: Never reinstall a cartridge with cleaning chemical residue as it can cause foaming and water chemistry issues
- Allow the cartridge to air dry if time permits, or reinstall immediately if needed
Method 3: Rotation System for Optimal Performance
Professional pool technicians recommend maintaining two sets of cartridge filters to ensure continuous filtration while cleaning.
- Purchase a duplicate set of cartridge filters for your specific system
- When it's time to clean, remove the dirty set and install the clean backup set
- Deep clean the dirty cartridges using Method 2 above
- Allow them to fully dry and store for the next rotation
- Rotate between sets every 2-4 weeks depending on pool usage and environmental factors
Signs Your Cartridge Filter Needs Attention
Unlike sand or DE filters where backwashing is scheduled, cartridge filter maintenance should be based on performance indicators:
- Reduced water flow: If your pool's return jets seem weaker than normal
- Shorter cleaning cycles: Pool gets dirty faster than usual
- Pressure gauge readings: If equipped, 8-10 PSI above clean starting pressure
- Visual inspection: Cartridge pleats are brown, gray, or clogged with debris
- Water clarity issues: Cloudy water that doesn't clear with proper chemical balance
When to Replace vs. Clean Cartridge Filters
Cartridge filters have a limited lifespan and eventually need replacement rather than cleaning:
- Replace when: Pleats start to fray or separate from the end caps
- Replace when: The fabric becomes permanently discolored and won't clean to near-white condition
- Replace when: Cleaning cycles become extremely frequent (weekly or more)
- Replace when: The cartridge has been in service for 12+ months regardless of condition
Cost Considerations
While cartridge filters require replacement rather than just backwashing, they often provide superior filtration compared to sand systems. Budget approximately $30-80 for replacement cartridges every 6-12 months depending on your system size and usage patterns.
If you're experiencing problems after cleaning cartridge filters:
- Poor flow after cleaning: Check that cartridges are properly seated and the housing lid is tight
- Continued cloudy water: May indicate cartridges are worn out or water chemistry needs adjustment
- Short time between cleanings: Consider more frequent skimming, checking water balance, or upgrading to larger capacity cartridges
Safety reminder: Always turn off electrical power to pool equipment before performing any filter maintenance to prevent injury from moving parts or electrical hazards.
