How to Backwash a DE Pool Filter: Complete Step Guide
Proper backwashing procedure for diatomaceous earth filter system?
I spent all morning watching my DE pool filter act completely bizarre — pressure gauge shooting way above normal while water flow drops to practically nothing. What is the precise step-by-step procedure for backwashing a diatomaceous earth filter system? I want to make sure I'm switching valve positions in the right order and running each cycle for the appropriate duration to maintain optimal filtration efficiency.
Turn off your pump, switch the multiport valve to 'Backwash', run for 2-3 minutes until water clears, then switch to 'Rinse' for 30 seconds before returning to 'Filter' and adding fresh DE powder.
Quick Solution
First question: when did your DE filter's backwash water stop running clear after the usual 2-3 minutes? The entire process takes about 10 minutes and should be done when pressure rises 8-10 PSI above clean levels.
Complete Backwashing Process
Pre-Backwash Preparation
Before starting, check your pressure gauge reading. A DE filter needs backwashing when the pressure rises 8-10 PSI above the clean starting pressure. For most residential pools, this occurs every 4-6 weeks during normal operation, though heavy bather loads or algae blooms may require more frequent backwashing.
Safety first: Always turn off the pump before moving the multiport valve to prevent damage to the valve and potential injury from pressurized water lines.
Step-by-Step Backwashing
- Turn off the pool pump at the circuit breaker or timer to ensure complete shutdown
- Rotate the multiport valve to 'Backwash' - never move the valve while the pump is running
- Turn the pump back on and let it run for 2-3 minutes, watching the sight glass on the valve
- Monitor the backwash water - it will start dirty and gradually clear as the DE cake is removed from the filter grids
- Turn off the pump when the sight glass shows relatively clear water
- Switch to 'Rinse' position and run the pump for 30 seconds to clear any remaining debris from the plumbing
- Turn off pump and return valve to 'Filter' position
- Restart the pump and note the clean starting pressure for future reference
Adding Fresh Diatomaceous Earth
After backwashing, your filter grids are clean but uncoated, providing minimal filtration until you add fresh DE. Calculate the correct amount based on your filter's square footage - typically 1 pound of DE per 10 square feet of filter area. Most residential DE filters require 4-8 pounds of DE powder.
Mix the DE powder in a bucket with pool water to create a slurry, then slowly pour it into the skimmer while the pump is running. This allows the DE to evenly coat the filter grids. Never add dry DE powder directly to the skimmer as it can clog the system.
When to Backwash Your DE Filter
Pressure rise is the primary indicator, but other signs include:
- Reduced water flow from return jets
- Cloudy water that doesn't clear after normal chemical adjustments
- Shortened time between chemical treatments
- Visible debris passing through return jets
Avoid backwashing too frequently, as a slightly dirty filter actually works more effectively than a completely clean one. The initial DE cake helps trap finer particles.
Pressure Won't Drop After Backwashing
If pressure remains high after backwashing, your filter grids likely need manual cleaning or replacement. Remove the grids and inspect for tears, permanent DE buildup, or oil contamination. Soak grids in a filter cleaner solution like Natural Chemistry Filter Perfect or muriatic acid solution (1 part acid to 10 parts water - always add acid to water, never water to acid) to remove oils and mineral deposits. Always wear safety goggles, gloves, and work in a well-ventilated area when handling muriatic acid.
Short Time Between Backwashes
Frequent backwashing indicates either poor water chemistry, excessive organic load, or damaged filter components. Test and balance your water chemistry first - maintain FC levels according to your CYA level using the FC/CYA chart, keep pH between 7.2-7.6, and ensure proper sanitizer residual.
DE Powder Returning to Pool
If you see DE powder in your pool after adding fresh DE, you have torn or damaged filter grids that need replacement. This is a common issue in older filters or when grids haven't been properly maintained.
Maintenance Tips for Optimal Performance
Between backwashes, maintain proper water chemistry to extend filter cycles. Keep your FC level appropriate for your CYA level - typically 2-4 ppm FC with 30-50 ppm CYA for most pools. Poor water balance forces your filter to work harder, shortening the time between backwashes.
Consider using a phosphate remover like Natural Chemistry PHOSfree if you're backwashing more frequently than every 3-4 weeks. High phosphate levels can feed algae growth, overwhelming your filtration system.
Schedule deep cleaning of your filter grids 2-3 times per season. Remove grids from the filter tank and clean with specialized filter cleaners to remove oils, lotions, and mineral deposits that regular backwashing can't eliminate.
Still need help? Ask a Pool & Spa Expert
