Equipment Equipment — How to Replace a Pool Light Bulb Without Draining the Water?
Brian Z.
Brian Z.
Snowbird Pool Owner
I noticed my pool light stopped working this morning and want to fix it without draining the pool. Can I replace the bulb or entire fixture underwater, and what's involved?
Short Answer Yes, you can replace a pool light without draining the water. Most large niche fixtures are removed from the deck side, with enough cord slack (typically 4-6 feet) coiled behind the fixture to pull it onto the dry deck. Note that nicheless LEDs (e.g. Pentair MicroBrite) are sealed, non-serviceable units with no service loop — you replace the whole light, not the bulb. Likely Causes: burned-out bulb (most common), a failed gasket, or a corroded socket or wiring.
Short Answer
Yes — for the most common type you can replace the bulb without draining. Classic large round niche fixtures (PAR56-style: Pentair AmerLite, Hayward AstroLite, and their LED drop-in replacements) are built to come out from the deck side — a single screw releases the fixture, and 4-6 feet of cord is coiled in the niche so you can lift the whole unit onto the dry deck. This is not universal, though — check what you have first.
First, Check What Kind of Light You Have
  • Large round niche fixture (PAR56): the deck-side pull-out method below applies — there is a service loop of cord to reach the deck.
  • Small nicheless LED (Pentair MicroBrite, Hayward ColorLogic nicheless, J&J, PAL, etc.): these sit in a shallow housing with the cord running straight into conduit — no coiled slack to pull to the deck, and many are sealed units with no field-replaceable bulb, so you swap the whole light rather than a bulb.
  • Any fixture whose cord was cut to length with no service loop: even a big niche light cannot reach the deck if the slack is not there — you will need a different approach or a pro.
If you have a sealed nicheless LED or no service loop, the steps below will not apply.
Likely Causes
  • Burned-out bulb (most common issue)
  • Water intrusion into the fixture due to failed gasket
  • Corroded or damaged socket/wiring
  • Cracked lens or compromised seal
Step-by-Step Fix
Step 1: Turn Off Power and Test GFCI (Critical)
Locate your pool light circuit breaker at the main panel and turn it OFF. Test your GFCI outlet by pressing the test button, then reset button to ensure it's functioning properly. This is non-negotiable—pool lights operate on 120V or low-voltage 12V — 120V can be lethal, and while 12V systems carry far less risk, you should still cut power before any electrical work. Verify power is off using a non-contact voltage tester before proceeding. Warning: Ensure your hands and work area are completely dry before handling any electrical components.
Step 2: Access the Light Fixture
From the deck, locate the light niche (set into a pool wall, typically 12–18 inches below the waterline). The fixture is held by a single mounting screw at the 12 o'clock position—sometimes hidden under a small tab. Use a large flathead screwdriver to loosen this screw. Don't remove it completely; just loosen it enough to release the fixture.
Step 3: Remove the Fixture
Gently pull the fixture out of the niche and onto the deck. The cord behind it has 4-6 feet of slack—never pull on the cord itself, only on the fixture housing. Place the fixture on a towel to protect your deck and ensure the work area remains dry.
Step 4: Open the Fixture
Remove the lens ring using a large spanner wrench or flathead screwdriver. This ring secures the lens to the housing. Set aside the old gasket—you'll replace this.
Step 5: Replace the Gasket
Remove the old gasket and clean the groove thoroughly. Install a NEW silicone or rubber gasket—never reuse the old one. A failed gasket is the #1 cause of water intrusion and fixture failure.
Step 6: Install the New Bulb
Install the correct replacement bulb (typically 12V or 120V, PAR56 or similar). Important: If replacing a halogen bulb, do NOT touch the glass with bare fingers—oils cause hot spots and premature burnout. Use a clean cloth or gloves when handling.
Step 7: Reassemble
Reassemble the lens ring and tighten firmly by hand, then an additional quarter-turn with your tool. The gasket should compress evenly around the entire circumference. Do not overtighten—you'll crack the lens. Ensure all seals are completely dry and properly seated.
Step 8: Reinstall the Fixture
Carefully coil the excess cord back into the niche behind the fixture as you guide it into place. Ensure the cord is not pinched. Align the fixture's notch with the niche's slot. Tighten the mounting screw firmly but avoid overtightening.
Step 9: Test
Only after complete reassembly and ensuring all seals are dry and properly installed, restore power and verify the light works properly.
When to Call a Pro
  • Cracked lens or cracked light niche
  • Damaged, brittle, or melted cord
  • Water inside the fixture (indicates seal failure with possible internal corrosion)
  • Fixture won't come free (may be stuck with calcium/scale)
  • Need to replace entire fixture or run new wiring
Safety Note
Electrical safety is paramount: Always turn off power at the breaker and verify with a voltage tester. Never work on a wet deck with power on or with wet hands. Ensure GFCI protection is in place and functioning (required by code). The fixture is heavy—support it fully when removing to prevent damage or injury. Never test electrical components until the fixture is completely reassembled and all seals are dry.
Tags: #equipment
