How to Raise CYA (Stabilizer) Levels in Your Pool - Complete Guide
Greg E.
What's the proper method to increase cyanuric acid levels?
Noticed my 8-year-old pool is starting to lose chlorine effectiveness despite normal chemical levels — turns out my stabilizer got diluted from recent water additions. What's the standard dosing rate for cyanuric acid additions, and what's the most effective application method? I want to avoid any mistakes that could result in overstabilization or uneven distribution throughout the pool system.
To raise CYA in your pool, add cyanuric acid (stabilizer) at a rate of 1 pound per 3,000 gallons to increase levels by approximately 30ppm. Add through skimmer or dissolve in bucket first.
Free Tool: CYA/Stabilizer Calculator - Calculate how much stabilizer to add to your pool.
First, Let's Diagnose Your CYA Situation
Before adding any chemicals, you need to determine your current CYA level and target level. Test your water using a reliable test kit like the Taylor K-2006C or TF-100. Never guess at chemical levels - always test first.
Your target CYA level depends on your pool type:
If your CYA is below these ranges, you'll need to raise it. Low CYA means your chlorine is being destroyed rapidly by UV rays, causing you to use excessive amounts of sanitizer.
Step-by-Step Process to Raise CYA
Calculate Your Dosage
  1. Determine your pool volume in gallons
  2. Test current CYA level with a proper test kit
  3. Calculate how much you need to increase CYA to reach your target
  4. Use this formula: Pool gallons ÷ 10,000 × desired ppm increase ÷ 10 = pounds of cyanuric acid needed
For example: 20,000-gallon pool with 10ppm CYA wanting to reach 40ppm needs: 20,000 ÷ 10,000 × 30 ÷ 10 = 6 pounds of cyanuric acid.
Choose Your Addition Method
You have two primary methods for adding cyanuric acid:
Method 1: Skimmer Addition (Easiest)
  1. With pump running, slowly pour granular cyanuric acid into your skimmer
  2. Add no more than 1-2 pounds at a time
  3. Allow to circulate for 24 hours before adding more
  4. Warning: This method can create localized low pH conditions that may damage equipment if added too quickly
  5. This method works because the acid dissolves slowly as water passes through
Method 2: Pre-Dissolving (Faster)
  1. Fill a 5-gallon bucket with warm pool water
  2. Slowly add cyanuric acid while stirring continuously
  3. Stir until completely dissolved (this can take 15-30 minutes)
  4. Pour dissolved solution around pool perimeter with pump running
  5. Brush pool to help distribution
Important Safety and Timing Considerations
Safety First: Always add chemicals to water, never water to chemicals. Wear safety glasses and avoid breathing dust when handling cyanuric acid. Work in a well-ventilated area. Cyanuric acid is highly acidic and can damage pool equipment if added improperly or too quickly.
Cyanuric acid dissolves very slowly - this is normal. Don't be tempted to add more if you don't see immediate results. It can take 2-7 days for granular cyanuric acid to fully dissolve and distribute throughout your pool.
Testing and Adjusting
  1. Wait at least 24-48 hours after final addition before testing
  2. Test CYA level using a proper test kit (not test strips)
  3. If levels are still low, repeat the process with additional cyanuric acid
  4. Once target CYA is reached, adjust your chlorine levels accordingly using the FC/CYA chart
Common Troubleshooting Issues
Problem: Added cyanuric acid but levels haven't increased
Solution: Wait longer - it can take up to a week to fully dissolve. Ensure pump is running for adequate circulation.
Problem: White powder settling on pool bottom
Solution: This is undissolved cyanuric acid. Brush it around to help dissolution, or use a pool vacuum to redistribute it.
Problem: CYA levels too high after addition
Solution: Unfortunately, you can only lower CYA by diluting with fresh water. This is why it's crucial to add gradually and test frequently.
Maintaining Proper CYA Levels
Once you've achieved proper CYA levels, they should remain stable. CYA doesn't evaporate or get consumed like chlorine. The only ways CYA levels decrease are:
Most pool owners need to add cyanuric acid only once or twice per season, typically after partial water changes or at pool opening.
Remember: After raising CYA, you'll need to adjust your daily chlorine target. Higher CYA means you need higher chlorine levels to maintain the same sanitizing effectiveness. Always reference the FC/CYA relationship chart when maintaining your pool chemistry.
cyanuric acid pool test kit 5-gallon bucket stirring stick safety glasses
Tags: #CYA #cyanuric acid #stabilizer #pool chemistry #chlorine protection
