How to Kill Pool Algae: Complete SLAM Method Guide 2024
What's the SLAM method for killing pool algae?
Despite moving into our new home last month, I discovered the previous owners left behind a pool that looks like a green swamp with algae covering every surface. Heard about something called the SLAM method but don't know the exact steps. How does it work and what chlorine levels do I need to maintain? Need the full process.
Kill pool algae using the SLAM method: shock your pool to the proper chlorine level based on your stabilizer, maintain that level until algae dies, and brush/vacuum debris.
Understanding Pool Algae and the SLAM Method
Nine times out of ten, when pool owners report green, slimy water that won't clear up despite shocking, the culprit is stubborn algae that demands the nuclear option. The most effective way to kill algae is using the SLAM method (Shock Level And Maintain), which involves raising free chlorine to a specific shock level and maintaining it until all algae dies.
Unlike traditional "shock and wait" approaches, SLAM requires maintaining elevated chlorine levels continuously until your pool passes an overnight chlorine loss test, ensuring complete algae elimination.
Testing Your Water Chemistry
Before adding any chemicals, test your water using a reliable test kit like the Taylor K-2006C. You need accurate readings for:
- Free Chlorine (FC) - Currently available chlorine
- Combined Chlorine (CC) - Chlorine tied up by contaminants
- Total Chlorine (TC) - FC + CC combined
- Cyanuric Acid (CYA) - Chlorine stabilizer level
- pH - Should be 7.2-7.6 for effective chlorine
Critical: If your combined chlorine exceeds 0.5 ppm, you'll need to address chloramines before starting SLAM. High CC levels indicate your chlorine is tied up and won't effectively kill algae.
Determining Your Shock Level
Your shock level depends on your CYA (stabilizer) level. Higher CYA requires more chlorine to be effective:
- CYA 30: Shock level 12 ppm FC
- CYA 40: Shock level 16 ppm FC
- CYA 50: Shock level 20 ppm FC
- CYA 60: Shock level 24 ppm FC
- CYA 70: Shock level 28 ppm FC
- CYA 80: Shock level 32 ppm FC
If your CYA exceeds 80 ppm, you'll need to partially drain and refill your pool before SLAM will be effective. High stabilizer levels make chlorine nearly useless against algae.
Executing the SLAM Process
Initial Shock Treatment
Add liquid chlorine (sodium hypochlorite) to reach your target shock level. Avoid calcium hypochlorite "shock" products during SLAM as they add calcium and raise pH excessively.
Dosing calculation: Each gallon of 12.5% liquid chlorine raises FC by approximately 1.28 ppm in 10,000 gallons of water. For a 20,000-gallon pool needing 20 ppm FC, you'd need about 31.25 gallons of liquid chlorine initially.
Daily Maintenance
Test FC levels twice daily (morning and evening) and add liquid chlorine to maintain your shock level. Don't let FC drop below your target - this allows surviving algae to regrow rapidly.
Brush your pool walls and floor vigorously twice daily. Dead algae must be physically removed from surfaces where it can cling tenaciously. Use a stainless steel brush for concrete pools or nylon for vinyl/fiberglass.
pH Management
Liquid chlorine raises pH, so you'll likely need muriatic acid to keep pH between 7.2-7.6. Add acid in small increments (1 quart per 10,000 gallons typically lowers pH by 0.2), wait 30 minutes, then retest.
Filtration and Cleaning
Run your filter 24/7 during SLAM. Clean DE or cartridge filters daily - dead algae clogs filters rapidly. For sand filters, backwash when pressure rises 8-10 psi above clean pressure.
Vacuum algae debris to waste when possible to avoid recirculating dead material through your filter. If you must vacuum to the filter, clean it immediately afterward.
Completing the SLAM Process
SLAM is complete when you pass the Overnight Chlorine Loss Test (OCLT):
- Add chlorine to reach shock level in the evening
- Test FC the following morning
- If FC loss is 1 ppm or less, and water is crystal clear, SLAM is complete
- If FC drops more than 1 ppm, continue SLAM for several more days
The OCLT confirms no living algae remains to consume chlorine overnight.
Post-SLAM Water Balancing
Once SLAM is complete, reduce FC to normal levels (1-4 ppm depending on CYA). Balance remaining chemistry:
- Total Alkalinity: 80-120 ppm for regular pools, 60-80 for salt water
- Calcium Hardness: 250-350 ppm for plaster, 150-250 for vinyl/fiberglass
- Salt Level: 2700-3200 ppm for salt water generators
Warning: Never swim during SLAM. High chlorine levels can cause severe skin and eye irritation. Wait until FC drops to safe levels (typically under 5 ppm) before allowing swimming.
Store liquid chlorine in a cool, dry place away from other chemicals. Never mix different pool chemicals together.
Prevention Tips
Prevent future algae blooms by maintaining proper FC levels daily, keeping CYA between 30-50 ppm (70-80 for salt pools), and running your pump adequate hours for complete water turnover. Regular brushing and proper water balance prevent most algae problems before they start.
