How to Add Pool Stabilizer: Complete CYA Addition Guide
What's the proper method for adding stabilizer to my pool?
CYA level dropped to 15 ppm after a heavy rain week and my chlorine is burning off by noon every day. Bought a bag of stabilizer but the instructions are vague — do I dissolve it first, pour it in the skimmer, broadcast it across the surface? Don't want to overdo it and end up with the opposite problem.
Add granular cyanuric acid one of two ways. The easy route is the sock method: put it in a sock, hang it at a return jet (or in the skimmer with the pump on), and squeeze it daily until it dissolves in 2-4 days. Or pre-dissolve it in a bucket of hot water and pour it around the pool with the pump running. Either way, target 30-50 ppm CYA (70-80 for a salt pool) and wait several days before retesting, since CYA reads low until it fully dissolves.
Understanding Stabilizer Basics
Good news: adding pool stabilizer is solidly DIY territory - no expensive service calls needed, just the right cyanuric acid product and our step-by-step process. This explains why your chlorine disappears so quickly in sunlight. Without adequate stabilizer, UV rays destroy free chlorine rapidly, leaving your pool vulnerable and requiring constant chemical additions.
The target range for CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → is typically 30-50 ppm for most pools (verify with your pool professional or manufacturer guidelines), with many experts recommending around 30 ppm as the sweet spot. You can use our all-in-one pool calculator to estimate how much stabilizer you need based on your pool volume and current levels.
Choosing Your Stabilizer Type
You'll typically encounter two options: granular cyanuric acid and liquid stabilizer. Granular cyanuric acid is the most common and cost-effective choice. It's pure CYA that requires dissolving before addition. Liquid stabilizer is more expensive but dissolves instantly - however, it often comes with sodium, which can contribute to total dissolved solids over time.
Granular cyanuric acid is the usual pick for most situations — it's what most pool professionals use. Just know it's only sparingly soluble, so it won't fully dissolve in a bucket; you pour in the slurry and brush up anything that settles (see below).
The Proper Addition Method
Never dump granular cyanuric acid directly into your pool. This creates several problems: it dissolves very slowly, is acidic enough to etch pool surfaces where it settles, and may clog your filter system. Instead, you'll need to pre-dissolve it.
Step-by-step process:
- For a handy reference to calculate a good estimate of the amount needed, use our all-in-one pool calculator. Alternatively, you can do it by hand using current CYA levels and pool volume.
- Fill a large bucket with the hottest tap water available (take care to avoid burns) - hot water dissolves CYA much faster than cold
- Slowly add the granular cyanuric acid while stirring continuously
- Stir for several minutes - but note CYA is only sparingly soluble, so a bucket won't fully dissolve a large dose. Hot water dissolves what it can and warms the rest; for a big dose, split it across a few buckets
- With your pump running, slowly pour the solution (and any undissolved slurry) around the pool perimeter, then brush any granules that settle so they finish dissolving
- Run your filtration system continuously for at least 24 hours
Prefer a hands-off option? Many pool owners skip the bucket entirely and use the sock method instead: put the granules in a clean sock or pantyhose, hang it in front of a return jet (or in the skimmer with the pump running), and squeeze it a few times a day. It's slower (2-4 days) but there's no slurry to pour and nothing settles on the floor, which makes it the easiest and lowest-risk way to add CYA for most pools.
Dissolution Tips That Actually Work
Many pool owners struggle with getting CYA to dissolve. The key is patience and hot water — and remembering it's only sparingly soluble, so some granules will finish dissolving in the pool rather than in the bucket. If you're having trouble, try adding the granules very slowly while maintaining constant agitation. Some pool owners report success using a paint mixer attachment on a drill for stubborn batches.
You might notice some temporary cloudiness after addition - this is normal and should clear within 24-48 hours with proper filtration.
Timing and Testing Considerations
CYA doesn't distribute evenly immediately after addition. Wait several days — up to a week — before retesting to get accurate readings. This waiting period is crucial; granular CYA dissolves slowly and reads low until it does, so testing too early shows falsely low readings and leads to over-addition.
Once you reach your target range, CYA levels remain relatively stable. Unlike chlorine or pH, stabilizer doesn't break down quickly. It does still decline slowly - mainly through water dilution (heavy rain, backwashing, partial draining) and a gradual bacterial breakdown that runs faster in warm water - so expect to top it up over a season.
For comprehensive guidance on maintaining proper water balance after adding stabilizer, check out our complete water chemistry guide.
The biggest error is adding too much stabilizer at once. High CYA levels (typically above 80-100 ppm, but verify acceptable ranges for your specific situation) can actually reduce chlorine effectiveness, creating over-stabilization, where chlorine becomes much less effective. Always add conservatively and test before adding more.
One caution you'll see repeated — that adding stabilizer near shocking causes problems — isn't really true. CYA dissolves the same regardless of chlorine level, so there's no chemical conflict and you can add it whenever it's convenient. Just give fresh CYA the usual several days to fully dissolve before you retest.
Finally, don't expect immediate results. Stabilizer takes time to fully incorporate into your pool water and begin protecting chlorine effectively. You should notice chlorine lasting longer within 2-3 days of proper addition.
