How Do Pool Filters Work? Complete Guide to Pool Filtration
Rebecca Z.
DIY Pool Enthusiast
Pool store keeps pushing expensive filters - how do they even work?
Already planned to swap out my pool filter this Saturday — but I'm completely lost on which type I actually need with all these confusing options. Last week they were pushing a $800 DE filter, then yesterday they're telling me I need a cartridge system that costs twice what I paid for my pump.
Before I get ripped off again, can someone explain how these different pool filters actually work? I keep hearing about sand filters, cartridge filters, and DE filters but nobody's ever explained the basics of how they clean the water. I'm handy enough to maintain my own equipment if I understand what's going on inside these things.
Pool filters work by forcing water through filtering media that traps debris and contaminants. The three main types are sand filters (using sand beds), cartridge filters (using pleated fabric), and DE filters (using diatomaceous earth powder).
How Pool Filtration Works
Most people don't realize that a typical pool filter processes your entire pool's water volume 2-3 times every single day, making it work harder than your home's HVAC system. Understanding how your specific filter type operates will help you maintain it properly and troubleshoot issues when they arise.
All pool filters work on the same basic principle: water is pumped from your pool through a filtering medium that traps particles, then clean water returns to the pool. However, the three main filter types - sand, cartridge, and diatomaceous earth (DE) - use different methods to achieve this filtration.
Sand Filter Operation
Sand filters are the most common type due to their durability and low maintenance requirements. Inside the tank, specially graded pool filter sand creates a bed typically 18-24 inches deep. As water flows down through this sand bed, particles get trapped in the spaces between sand grains.
The filtration process happens in layers. Larger debris gets caught in the top layer, while progressively smaller particles are trapped deeper in the sand bed. This creates a biological layer that actually improves filtration efficiency over time.
Sand filters can trap particles down to about 20-40 microns in size. While this isn't the finest filtration available, it's adequate for most pools when combined with proper water chemistry. The pump typically runs water through the sand at a rate of 12-15 gallons per minute per square foot of filter area.
Backwashing is crucial for sand filter maintenance. When pressure rises 8-10 PSI above the clean starting pressure, you reverse the water flow to flush trapped debris out through the waste line. This process typically takes 2-3 minutes until the water runs clear in the sight glass.
Cartridge Filter Systems
Cartridge filters use pleated polyester or paper elements that provide much finer filtration than sand - typically catching particles as small as 5-15 microns. The pleated design dramatically increases the surface area available for filtration within a compact space.
Water flows through the cartridge material from outside to inside, with debris trapped on the outer surface and in the pleats. Multiple cartridges are usually installed in the filter housing to provide adequate flow rate and dirt-holding capacity.
The flow rate through cartridge filters is generally lower than sand filters - typically 2-4 gallons per minute per square foot of cartridge area. This slower flow rate contributes to the superior filtration quality.
Maintenance involves removing and cleaning cartridges every 2-4 weeks, depending on bather load and environmental factors. Rotate between two sets of cartridges, allowing cleaned ones to dry completely before reinstalling, which helps extend their lifespan.
Diatomaceous Earth (DE) Filter Function
DE filters provide the finest filtration available for pools, capturing particles as small as 2-5 microns. They use a white powder made from fossilized diatoms that coats grids inside the filter tank.
The DE powder forms a thin "precoat" layer on fabric-covered grids. As water passes through this layer, the microscopic pores in the diatomaceous earth trap extremely fine particles. The result is exceptionally clear, polished-looking water.
After backwashing a DE filter, you must add fresh DE powder to recoat the grids. The typical amount is 1 pound of DE per 10 square feet of filter area, added through the skimmer with the pump running.
Safety warning: Always use pool-grade DE and wear a dust mask when handling it, as the powder can irritate lungs and eyes.
Circulation and Turnover Rate
Regardless of filter type, proper circulation is essential for effective filtration. Your pool should complete at least one full turnover every 8-12 hours, meaning all the water passes through the filter system once during that period.
Calculate your turnover rate by dividing pool volume by pump flow rate. For a 20,000-gallon pool with a pump moving 50 GPM: 20,000 ÷ (50 × 60) = 6.7 hours for complete turnover.
Dead spots in your pool where water doesn't circulate well will accumulate debris and algae. Proper return jet positioning and running your system long enough each day ensures all water gets filtered regularly.
Filter Efficiency and Water Chemistry
Remember that filtration alone doesn't create healthy swimming water - it works hand-in-hand with proper sanitation. Chlorine kills bacteria and algae, while the filter removes the dead organic matter and other debris.
Maintain free chlorine at 1-3 PPM (higher levels needed when stabilizer is present), pH between 7.2-7.6, and total alkalinity at 80-120 PPM for conventional pools. These parameters ensure your sanitizer works effectively while protecting your filter equipment.
Shocked or cloudy water puts extra strain on filters, so maintain consistent water chemistry to reduce filter workload and extend equipment life.
pressure gauge pool test kit
Tags: #sand filter #cartridge filter #DE filter #filtration #circulation
