How to Fix Green Pool Water Fast - SLAM Method Guide 2024
Is it safe to let kids swim once green pool water is treated?
I tried everything but my pool has bright green water, slimy algae coating the walls, AND I can't even see the bottom anymore. I've heard about something called the SLAM method to fix green water, but I need to know if this actually makes the water safe for my children to swim in again.
What exactly is the SLAM method and how do I know when the water is completely clear and safe? I want to make sure I'm not rushing the process and putting my kids at risk. How long does this treatment usually take to work?
Green pool water can absolutely be fixed using the SLAM method (Shock Level And Maintain). This involves raising free chlorine to shock levels based on your CYA and maintaining that level until the pool clears completely.
The SLAM Method: Your Best Solution
SLAM stands for Shock Level And Maintain, and it's the gold standard for clearing green, algae-filled pools. Unlike store-bought "shock" products that often contain unnecessary additives, this method uses pure liquid chlorine (sodium hypochlorite) to effectively kill algae and restore crystal-clear water.
Why SLAM Works Better Than Pool Store Methods
Traditional pool store advice often involves multiple expensive products like algaecides, clarifiers, and stabilized shock. The SLAM method is more effective because:
- Liquid chlorine provides pure sanitizing power without clouding agents
- Maintaining shock levels ensures complete algae elimination
- No interference from unnecessary chemicals that can actually slow the process
- Costs significantly less than multiple specialty products
Step-by-Step SLAM Process
Before starting, you need accurate readings of your current levels. Use a reliable test kit like the Taylor K-2006C:
- Free Chlorine (FC)
- Combined Chlorine (CC)
- pH
- Total Alkalinity (TA)
- Cyanuric Acid (CYA)
Critical: If your CYA is above 80 ppm, you'll need to partially drain and refill your pool first, as shock levels become impractically high.
Step 2: Adjust pH and Alkalinity
Lower your pH to 7.2-7.4 using muriatic acid before beginning SLAM. This makes chlorine more effective at killing algae. If your total alkalinity is above 120 ppm, lower it to 80-100 ppm to prevent pH from rising too quickly during the process.
Step 3: Calculate Your Shock Level
Your shock level depends on your CYA reading:
- CYA 30 ppm = 12 ppm FC shock level
- CYA 40 ppm = 16 ppm FC shock level
- CYA 50 ppm = 20 ppm FC shock level
- CYA 60 ppm = 24 ppm FC shock level
- CYA 70 ppm = 28 ppm FC shock level
Step 4: Add Liquid Chlorine
Use 10.75% liquid chlorine (sodium hypochlorite). To raise FC by 10 ppm in a 20,000-gallon pool, add approximately 1 gallon of 10.75% liquid chlorine. Adjust proportionally for different pool volumes. Always add chlorine with the pump running and distribute around the pool perimeter.
Safety Warning: Never mix chlorine with other chemicals. Add chlorine separately and allow circulation between additions.
Step 5: Maintain Shock Levels and Brush Daily
Test FC levels every few hours and add chlorine as needed to maintain your shock level. Brush all pool surfaces daily to break up algae biofilms and improve chlorine contact. During active algae killing, chlorine consumption will be very high - potentially requiring multiple additions per day.
What to Expect During SLAM
Timeline and Visual Changes
Day 1-2: Pool may get cloudier or darker green as dead algae particles circulate. This is normal and indicates the process is working.
Day 2-4: Water typically begins clearing from deep green to lighter green to cloudy blue-green.
Day 3-7: Pool becomes increasingly clear. Continue maintaining shock levels even after it looks clear.
The Overnight Chlorine Loss Test (OCLT)
Your pool isn't truly clear until it passes the OCLT. Test FC in the evening, then again the next morning before sunrise. If FC drops less than 1 ppm overnight for two consecutive nights, SLAM is complete.
- Using calcium hypochlorite shock: This adds calcium and can cloud your water
- Adding algaecide: Most algaecides interfere with chlorine testing and aren't necessary
- Stopping too early: Pools that look clear may still fail the OCLT
- Not running the pump 24/7: Continuous circulation is essential during SLAM
- Ignoring filter maintenance: Clean or backwash frequently as dead algae clogs filters
Filter Maintenance During SLAM
Your filter will work overtime removing dead algae. For cartridge filters, rinse daily and rotate between multiple sets. For sand filters, backwash when pressure rises 8-10 psi above clean levels. DE filters may need daily backwashing and fresh DE powder.
When Is It Safe to Swim After Green Water Treatment?
Before allowing anyone to swim, especially children, ensure these safety criteria are met:
- SLAM process is complete (passes OCLT for two consecutive nights)
- Combined chlorine (CC) is below 0.5 ppm
- Free chlorine has returned to normal swimming range (approximately 5-7.5% of your CYA level)
- pH is between 7.2-7.6
- You can clearly see the bottom and main drain
- Pool has circulated for at least 8 hours after final chemical adjustments
Post-SLAM Pool Maintenance
Once swimming safety criteria are met, resume regular testing 2-3 times weekly and maintain proper chemical balance to prevent future algae blooms.
