How to Fix Cloudy Pool Water Fast - 5 Step Solution
Linda D.
Pool water cloudy - what's the fastest way to clear it up?
Our first pool season just turned into a nightmare when we woke up to water that looks like straight-up milk and we're completely clueless. What's the quickest method to fix this? Should I shock it or just run the filter more?
Looking for a step-by-step approach that actually works. Don't want to waste time on methods that take forever.
Fix cloudy pool water by immediately shocking to proper levels based on your CYA, running your filter 24/7, and maintaining proper chemical balance until water clears in 24-48 hours.
Quick Solution
Most people don't realize that adding more chlorine to cloudy pool water often makes the problem worse, not better. Most cloudy water clears within 24-48 hours with proper shocking and filtration. Add liquid chlorine to reach shock level, run your pump 24/7, backwash when pressure rises 8-10 psi, and maintain shock level until water is crystal clear.
Immediate Action Steps
  1. Test your water chemistry - Use a quality test kit like Taylor K-2006C to measure Free Chlorine (FC), pH, Total Alkalinity (TA), and Cyanuric Acid (CYA). These numbers determine your exact treatment plan.
  2. Calculate shock level - Your shock level depends on CYA. For 30 ppm CYA, shock to 12 ppm FC. For 50 ppm CYA, shock to 20 ppm FC. Use the FC/CYA chart: divide CYA by 10, then multiply by 4 for minimum shock level.
  3. Add liquid chlorine immediately - Use 12.5% liquid chlorine (sodium hypochlorite), not granular shock. Add 1 gallon of liquid chlorine per 10,000 gallons to raise FC by approximately 10-12 ppm. Calculate your exact needs for initial shocking.
  4. Run filter continuously - Set your pump to run 24/7 until water clears. Cloudy water means your filter is working overtime to capture particles. Don't give it a break until the job is done.
  5. Backwash frequently - For sand and DE filters, backwash when pressure gauge rises 8-10 psi above clean starting pressure. For cartridge filters, rinse every 6-12 hours during treatment for cloudy water.
Maintain Shock Level
This is the critical step most people miss. Test your FC every 4-6 hours and add more liquid chlorine to maintain shock level. Cloudy water consumes chlorine rapidly as it oxidizes contaminants. If FC drops below shock level, the process stalls and takes much longer.
Add liquid chlorine in smaller doses throughout the day rather than one large dose. For a 20,000-gallon pool maintaining 15 ppm FC, you might need to add 1/2 gallon every 6 hours initially. As water clears, chlorine consumption decreases.
Fix pH and Alkalinity Issues
Cloudy water often indicates pH problems. Test and adjust pH to 7.4-7.6 for optimal chlorine effectiveness. If pH is above 7.8, add muriatic acid. Use muriatic acid carefully - start with 1 pint per 20,000 gallons and retest, as the pH drop depends on your starting alkalinity and pH levels.
Total Alkalinity should be 80-120 ppm for most pools (60-80 for salt water generators). Low TA causes pH to bounce around, making it hard to maintain proper chlorine levels. Add sodium bicarbonate (baking soda) at 1.5 lbs per 10,000 gallons to raise TA by 10 ppm.
Address Root Causes
While shocking clears cloudy water, identify why it happened to prevent recurrence:
When Water Should Clear
Properly shocked pools with good filtration typically clear within 24-48 hours. If water isn't noticeably clearer after 24 hours, check these issues:
Safety Warnings
Never swim in cloudy water - you can't see the bottom, creating drowning risk. Wait until water is crystal clear before allowing swimming.
Add chemicals safely - Pour liquid chlorine slowly around pool perimeter with pump running. Never mix different chemicals together. Store chemicals in cool, dry location away from other pool chemicals.
Expected Timeline and Costs
Most cloudy water situations resolve in 1-3 days with proper treatment. Severely cloudy or green water may take 5-7 days. Budget $20-40 for liquid chlorine and test kit reagents for typical cloudy water treatment. Prevention through regular maintenance costs far less than emergency treatments.
pool test kit liquid chlorine muriatic acid sodium bicarbonate pool brush
Tags: #cloudy water #pool shock #SLAM method #liquid chlorine #pool chemistry
