How to Clear Cloudy Pool Water: Complete Step-by-Step Guide
Dan U.
Still have cloudy water after shocking - what am I missing?
Planning to tackle my weeks-long cloudy pool problem but torn between going with shock treatments versus clarifier chemicals. My pool has been cloudy for over a week now and I've already dumped what feels like half a pool store worth of chemicals into it. I've shocked it twice, added algaecide, clarifier - you name it. The water is still that milky white cloudy mess that makes me want to just fill the thing with concrete.
I know there has to be something I'm doing wrong with the process. Maybe I'm not testing something I should be? Or not running the filter long enough? I'm willing to try whatever it takes at this point because summer's not waiting for me to figure this out.
To clear cloudy pool water, test and balance your water chemistry, shock to the proper level based on your CYA, run the filter continuously, and maintain shock level until the water clears completely.
Step-by-Step Guide to Clear Cloudy Water
  1. Test Your Water Chemistry
    Use a reliable test kit like the Taylor K-2006 to test FC (free chlorine), pH, TA (total alkalinity), CYA (cyanuric acid/stabilizer), and CH (calcium hardness). Record all readings as they'll guide your treatment plan.
  2. Balance pH First
    If pH is above 7.6, add muriatic acid to bring it down to 7.4-7.6 range. High pH prevents chlorine from working effectively. Add muriatic acid gradually in small amounts (start with 1-2 cups per 10,000 gallons), as the exact amount depends on starting pH and total alkalinity levels. Wait 2 hours and retest.
  3. Adjust Total Alkalinity if Needed
    If TA is outside 80-120 range (60-80 for salt water pools), adjust using muriatic acid to lower or sodium bicarbonate to raise. Target 100 ppm for most pools.
  4. Determine Your Shock Level
    Based on your CYA level, determine the required shock level FC:
    • CYA 30: Shock level 12 ppm FC
    • CYA 40: Shock level 16 ppm FC
    • CYA 50: Shock level 20 ppm FC
    • CYA 60: Shock level 24 ppm FC
  5. Calculate Chlorine Needed
    Use liquid chlorine (sodium hypochlorite) - typically 1 gallon of 12.5% sodium hypochlorite raises FC by approximately 12.5 ppm in 10,000 gallons (check product label for exact concentration). Calculate how much you need to reach shock level and add it all at once, preferably in the evening.
  6. Start Continuous Filtration
    Run your pool pump and filter 24/7 until water clears. Clean or backwash your filter before starting. If you have a cartridge filter, have spare cartridges ready as they'll need frequent cleaning.
  7. Brush Pool Surfaces
    Brush walls, steps, and floor thoroughly to dislodge any particles or biofilm that may be contributing to cloudiness. Pay special attention to areas with poor circulation.
  8. Test FC Every 8-12 Hours
    Test your FC level twice daily. If it drops below shock level, add more liquid chlorine to bring it back up. The FC will drop quickly initially as it kills contaminants.
  9. Maintain Shock Level Until Clear
    Continue adding chlorine to maintain shock level until:
    • Water is crystal clear
    • FC level holds steady for 24 hours without significant drop
    • CC (combined chlorine) is 0.2 ppm or less
  10. Clean Filter Regularly
    Clean cartridge filters daily or backwash sand/DE filters when pressure rises 8-10 psi above clean pressure. Dirty filters cannot clear cloudy water effectively.
  11. Consider Clarifier if Needed
    If cloudiness persists after 48 hours of proper shocking and filtration, add a clarifier like Natural Chemistry Pool Perfect or BioGuard Polysheen Blue. Follow label directions carefully.
  12. Return to Normal Operation
    Once water is clear and FC holds steady, reduce chlorine to normal operating level (consult CYA/FC chart for proper levels - typically 3-5 ppm for CYA 30, 4-6 ppm for CYA 40, 5-7 ppm for CYA 50) and resume normal filtration schedule.
Common Causes of Cloudiness
Understanding why your pool became cloudy helps prevent future issues:
Important Safety Notes
Warning: Never swim in cloudy water as visibility is compromised and you cannot see someone in distress. Always add chemicals with pump running for proper circulation, and never mix different chemicals together.
Expected Timeline
Most cloudy water clears within 24-48 hours when properly treated. Severely cloudy or green water may take 3-7 days. The key is patience and maintaining proper chemical levels throughout the process.
pool test kit liquid chlorine muriatic acid pool brush measuring cup
Tags: #cloudy water #pool shocking #water chemistry #filtration #pool maintenance
