Can Salt Water Pools Make You Sick? Health Risks & Solutions
Are salt water pools actually safer or just expensive marketing?
My family's been pushing me to convert our chlorine pool to saltwater, but I'm torn between spending thousands on the upgrade versus sticking with what works.
I've been dealing with skin irritation from my regular chlorine pool and considering the switch, but I don't want to spend all that money just to end up with different health problems. Can salt water pools cause illness if something goes wrong with the chemistry? I'm looking for honest answers about the real health risks versus benefits before I blow my budget on what might just be fancy marketing.
Salt water pools can make you sick if the chemistry is imbalanced, allowing bacteria and algae growth. Properly maintained salt water pools with correct chlorine levels are actually gentler and safer than traditional pools.
First, Let's Diagnose the Problem
Before jumping to solutions, we need to identify what's actually making you sick. Salt water pool illness typically stems from one of these issues:
Check Your Water Chemistry
Test your water immediately using a reliable test kit like the Taylor K-2006C. Look for these warning signs:
- Free Chlorine (FC) below 1.0 ppm - Insufficient sanitization allows bacteria growth
- pH above 7.8 or below 7.0 - Reduces chlorine effectiveness and causes irritation
- Total Alkalinity outside 80-120 ppm range - Causes pH instability in salt water pools
- Cyanuric Acid (CYA) above 80 ppm - Chlorine lock prevents effective sanitization
Visual Inspection Signs
Look for these physical indicators of problems:
- Cloudy or hazy water
- Green, yellow, or pink water tinting
- Slimy surfaces on pool walls or steps
- Strong chemical smell (indicates chloramines, not free chlorine)
- Foam or bubbles that persist
Common Symptoms from Contaminated Salt Water Pools
- Skin rashes, itching, or burning sensation
- Red, irritated eyes or eye infections
- Respiratory irritation or coughing
- Ear infections
- Stomach upset or diarrhea (from accidentally ingesting contaminated water)
Step-by-Step Solutions
Immediate Actions for Contaminated Pool
- Stop swimming immediately until water chemistry is corrected
- Test your salt cell generator - Check if it's producing adequate chlorine. Most units should show 3,000-4,000 ppm salt levels
- Manually add liquid chlorine if FC is below 3.0 ppm. Add 1 gallon of 12.5% sodium hypochlorite per 10,000 gallons to raise FC by approximately 1.3 ppm
- Test and adjust pH first - Add muriatic acid if pH is above 7.6. Amount needed varies based on current pH and total alkalinity levels - see manufacturer guidelines
SLAM Process for Severely Contaminated Pools
If your pool is green, cloudy, or showing signs of algae/bacteria growth, perform a SLAM (Shock Level And Maintain) process:
- Calculate your shock level using the FC/CYA chart. With CYA at 30-50 ppm (recommended for salt water pools), maintain FC at appropriate shock levels per FC/CYA chart
- Add liquid chlorine to reach shock level. Amount needed depends on current FC level and target shock level - calculate based on your specific water test results
- Run filtration 24/7 during SLAM process
- Brush pool surfaces twice daily to remove biofilm where bacteria hide
- Test FC every 2-4 hours and add chlorine to maintain shock level
- Continue until overnight FC loss is less than 1.0 ppm and water is crystal clear
Ongoing Prevention Measures
- Test water 2-3 times weekly during swimming season, focusing on FC and pH
- Clean salt cell monthly with muriatic acid solution (1:10 ratio) to remove calcium buildup
- Maintain proper CYA levels between 30-50 ppm for salt water generators (check manufacturer specifications)
- Shock weekly with liquid chlorine even with salt generator running to break down chloramines
Why Salt Water Pools Get Contaminated
Many pool owners mistakenly believe salt water pools don't need chlorine or chemical maintenance. The truth is salt water generators simply convert salt into chlorine through electrolysis. When the generator fails, salt levels drop, or water chemistry gets imbalanced, sanitization suffers just like any pool.
Common misconceptions that lead to problems:
- "Salt water pools don't need chemicals" - False, they still need balanced pH, alkalinity, and adequate chlorine
- "The generator handles everything" - Generators can fail, get scaled up, or produce insufficient chlorine during high bather loads
- "Salt is natural so it's always safe" - Improperly maintained salt water can harbor the same pathogens as any untreated water
Contact a healthcare provider if you experience:
- Persistent eye infections or vision problems
- Severe skin reactions or rashes that don't improve
- Respiratory symptoms lasting more than 24 hours
- Signs of ear infection (pain, discharge, hearing changes)
- Gastrointestinal symptoms lasting more than 48 hours
Remember, properly maintained salt water pools are actually gentler on skin and eyes than traditional chlorine pools because they produce a more stable form of chlorine with fewer harsh byproducts. The key is consistent monitoring and maintenance to prevent the conditions that allow harmful microorganisms to thrive.
