Can Pools Leak? Common Causes & How to Detect Pool Leaks
Is my 20,000 gallon pool losing water from a leak or evaporation?
After two weeks of watching my pool devour water at 3/4 inch per day with zero swimmers, I'm convinced there's a serious leak somewhere. My pool is 20,000 gallons, rectangular, and about 8 years old. The water chemistry seems fine - chlorine at 2.5 ppm, pH at 7.4, alkalinity at 110 ppm.
I know pools naturally lose some water to evaporation, especially here in Arizona where it's been hitting 105°F daily. But this seems like a lot more than usual. I've checked around the equipment pad and don't see any obvious puddles or wet spots. The pool company that installed it said minor water loss is normal, but I'm starting to worry this might actually be a leak.
What's the normal amount of water loss I should expect from evaporation alone? At what point should I be concerned that this is actually a structural leak rather than just normal evaporation? I want to catch any potential problems before they get worse and more expensive to fix.
Yes, pools can leak due to structural damage, equipment failures, or plumbing issues. Pools commonly lose about 1/4 to 1/2 inch of water per day to evaporation, but in hot, dry, windy climates (such as Arizona summers) evaporation alone can approach or exceed 1/2 inch a day. Because there is no single universal number, run a bucket test to confirm whether the loss is evaporation or a leak.
Understanding Normal Water Loss vs. Leaks
Before assuming your pool has a leak, it's important to understand normal water loss. Pools naturally lose water through evaporation, especially during hot, windy, or dry conditions. The average pool loses 1/4 to 1/2 inch of water per day through evaporation alone. Factors that increase evaporation include:
- High temperatures and direct sunlight
- Wind exposure
- Low humidity
- Pool features like waterfalls or fountains
- Heavy swimmer activity
If your pool is losing more than your local evaporation rate consistently (verify with a bucket test, since desert climates can evaporate 1/2 inch or more per day on their own), or if the water level drops noticeably overnight when evaporation is minimal, you likely have a leak.
Common Causes of Pool Leaks
Structural Leaks
The pool structure itself can develop leaks over time. In concrete pools, cracks can form due to ground settling, freeze-thaw cycles, or normal aging. These cracks often start small but can expand if not addressed. Vinyl liner pools can develop tears from sharp objects, UV damage, or chemical imbalance that weakens the liner material. Fiberglass pools, while generally more leak-resistant, can develop cracks at stress points or from ground movement.
Plumbing System Failures
The underground plumbing system is a common leak source. PVC pipes can crack from ground movement, freezing, or age-related deterioration. Joints and fittings are particularly vulnerable, especially where pipes connect to the pool structure. Return lines, skimmer lines, and main drain connections are frequent leak points.
Equipment-Related Leaks
Pool equipment can also cause water loss. Pump seals, filter housing O-rings, and valve seals can deteriorate and leak. Skimmers and return fittings may lose their seal against the pool wall. Automatic pool covers, salt water chlorinator cells, and heater heat exchangers are other potential leak sources.
Simple Leak Detection Methods
The Bucket Test
This is the most reliable DIY method to confirm whether you have a leak. Fill a bucket with pool water and place it on a pool step, ensuring the water level inside matches the pool level. Mark both water levels and check after 24 hours. If the pool level dropped more than the bucket level, you have a leak.
Visual Inspection
Look for obvious signs around your pool area:
- Wet spots or soggy ground around the pool
- Cracks in the pool deck or coping
- Air bubbles coming from return jets (indicates suction-side leak)
- Unusually lush grass or vegetation near underground plumbing
- Visible cracks in concrete pools
- Tears or loose areas in vinyl liners
Dye Testing
For suspected structural leaks, use pool leak detection dye near suspected areas with the pump off. The dye will be drawn toward any leak points, making them visible.
When Leaks Become Serious Problems
Warning: Ignoring pool leaks can lead to expensive damage. Small leaks often become larger over time, and the escaping water can undermine pool decking, damage landscaping, and even affect your home's foundation. Additionally, constantly adding makeup water affects your chemical balance and increases utility costs.
Structural leaks in the deep end or main body of concrete pools require immediate professional attention. These can indicate serious foundation issues that may compromise pool integrity if left untreated.
Professional Leak Detection
While homeowners can identify obvious leaks, professional leak detection services use specialized equipment to locate hidden leaks precisely. They employ electronic listening devices, pressure testing equipment, and underwater cameras to pinpoint leak locations without unnecessary excavation.
Professional detection is especially valuable for:
- Underground plumbing leaks
- Leaks beneath pool decking
- Multiple leak sources
- Leaks that DIY methods cannot locate
Prevention and Maintenance
Regular maintenance helps prevent many leak-causing issues. Maintain proper chemical balance to prevent liner deterioration or concrete etching. Keep pH between 7.2-7.6, total alkalinity between 80-120 ppm, and calcium hardness to 250-350 ppm for plaster/concrete pools, or 175-225 ppm for vinyl and fiberglass pools. Monitor for settling or movement around your pool area, and address small cracks before they expand.
Have your pool professionally inspected annually, especially if it's over 10 years old. This can identify potential problem areas before they become major leaks.
