Can Pool Leak Through Concrete? Yes - Here's How to Fix
Is it possible for pool water to leak directly through concrete?
Woke up this morning to find my pool water level had dropped another two inches overnight and now I'm wondering if water is somehow seeping through the concrete itself. My kids spend hours in the pool every day, and I've noticed the water level dropping more than usual lately.
I always thought concrete was completely waterproof, but now I'm wondering if that's actually true. Can pool water actually leak through the concrete shell itself? I'm worried about what this might mean for water quality and whether it's safe for the kids to keep swimming if there are structural issues with the concrete.
Yes, pools can leak through concrete when it develops cracks, becomes porous over time, or has structural joint failures. The concrete shell itself can allow water to seep through, especially in older pools or those with poor initial construction.
One reassurance for parents: a slow structural or crack leak is a water-loss and structural concern, not a sanitation one. As long as you keep your chlorine and pH in range, the leak itself doesn't make the water unsafe for the kids to swim in.
How Concrete Pool Leaks Happen
Concrete pools rely on a waterproof barrier system, not just the concrete itself. The concrete shell provides structure, but waterproofing comes from plaster, paint, or membrane systems. When these fail or when the concrete develops structural issues, leaks occur through several mechanisms:
- Structural cracks: Ground movement, settling, or freeze-thaw cycles create cracks that penetrate the full concrete thickness
- Cold joints: Where concrete pours meet, incomplete bonding creates weak points that can separate over time
- Honeycomb concrete: Poor mixing or placement creates porous areas with interconnected voids
- Shrinkage cracks: As concrete cures, it shrinks and can develop hairline cracks that widen over time
- Plaster separation: When plaster pulls away from concrete, water can migrate behind the surface layer
Identifying Concrete Leaks
Before attempting repairs, confirm you have a concrete leak versus equipment or plumbing leaks:
- Perform the bucket test: Fill a bucket with pool water and place it on the pool step. Mark water levels in both pool and bucket. After 24 hours, if the pool water drops more than the bucket, you have a leak
- Check for visible cracks: Inspect the pool shell systematically, looking for cracks in corners, at the waterline, and where walls meet the floor
- Look for wet soil: Walk around the pool perimeter checking for consistently damp or sinking areas
- Perform dye testing: With the pump OFF and the water completely still, release food coloring near suspected cracks; hydrostatic pressure will draw the dye into an active leak
- Monitor water loss patterns: If water stops dropping at a certain level, the leak is likely at that depth
Temporary Quick Fixes
While permanent repairs require draining and professional work, these temporary solutions can slow leaks:
- Pool putty: Underwater epoxy putty like Epoxybond Pool Putty (Atlas Minerals) can temporarily seal small cracks. Clean the area, knead the putty, and press firmly into the crack
- Liquid sealers: Products like Leak Seal or Fix-A-Leak circulate through your system and may plug small leaks temporarily
- Hydraulic cement: For accessible cracks above water level, hydraulic cement provides a quick temporary patch
Safety Warning: These are temporary measures only. Structural concrete cracks indicate serious issues that require professional evaluation to prevent pool failure or collapse.
Permanent Concrete Leak Repair
Proper concrete leak repair requires draining the pool and addressing the root cause:
Crack Injection Method
- Clean the crack: Use a grinder to create a V-groove along the crack, removing loose material
- Install injection ports: Drill holes and install plastic ports every 6-8 inches along the crack
- Seal the surface: Apply epoxy paste over the crack and ports, leaving only port openings exposed
- Inject repair material: Use low-pressure injection to fill the crack with polyurethane or epoxy resin
- Apply surface seal: Once cured, grind smooth and apply new waterproof coating
Concrete Replacement Method
For severely damaged areas:
- Cut out damaged concrete: Use a concrete saw to create clean edges around the damaged area
- Prepare the surface: Clean thoroughly and apply bonding agent to existing concrete
- Place new concrete: Use high-quality concrete mix with appropriate admixtures for pool applications
- Cure properly: Keep concrete moist for 7-14 days for proper strength development
- Apply waterproofing: Install new plaster, paint, or membrane system
Prevention Strategies
Prevent future concrete leaks by addressing underlying causes:
- Maintain proper water chemistry: Keep pH between 7.4-7.6 and total alkalinity at 80-120 ppm to prevent concrete degradation
- Control calcium hardness: Maintain 250-350 ppm for plaster pools to prevent etching or scaling
- Address drainage issues: Ensure proper drainage around the pool to prevent hydrostatic pressure
- Monitor ground movement: Address settlement issues early before they cause structural damage
- Maintain surface coatings: Resurface plaster or repaint as recommended to maintain waterproof barrier
When to Call Professionals
Contact a structural engineer or pool contractor immediately if you notice:
- Cracks wider than 1/8 inch
- Horizontal cracks in pool walls
- Multiple cracks appearing simultaneously
- Cracks that continue growing after repair
- Significant ground settlement around the pool
- Water loss exceeding 2 inches per week
Concrete pool leaks often indicate underlying structural issues that can worsen rapidly if not properly addressed. While temporary fixes may slow water loss, permanent solutions require identifying and correcting the root cause of the concrete failure.
