Do I Need a Pool Cleaner? Investment Worth Guide 2026
Is investing in an automatic pool cleaner actually worth it?
I got a pool cleaner sitting in my cart right now but can't shake the feeling I'm about to waste money on something I could just do myself. My neighbor swears by his robotic cleaner, but they're pretty expensive. I've got a standard rectangular inground pool with a cartridge filter system. Been maintaining it myself for about two years now, but the manual cleaning is becoming a real chore. Do I really need to buy an automatic cleaner, or am I just being lazy? What's the real difference in water quality?
You don't absolutely need an automatic cleaner, but it significantly reduces maintenance time and often provides better cleaning consistency. The investment makes sense for most pool owners who value convenience and thorough debris removal.
The Bottom Line: It's About Time vs. Money
You don't technically need an automatic pool cleaner - manual vacuuming can absolutely keep your pool clean when done properly and consistently. However, I'd recommend investing in one if you value your time and want more consistent cleaning results. Most pool owners find that automatic cleaners typically pay for themselves in reduced maintenance time and better water quality relatively quickly.
When Manual Cleaning Falls Short
Manual vacuuming works fine for small debris and routine maintenance, but it has limitations. You're likely missing spots, especially around steps, corners, and under skimmers where debris tends to accumulate. Manual cleaning also requires you to be present and engaged - no cleaning happens when you're busy, traveling, or just don't feel like doing it.
Automatic cleaners work continuously or on schedules, catching debris before it breaks down and affects your water chemistry. This is particularly important because organic debris consumes chlorine and can lead to algae growth if left sitting on the pool floor.
Choosing the Right Type for Your Situation
With your cartridge filter system, you have three main options, each with different benefits:
Robotic Cleaners (Best Overall)
These are self-contained units with their own filtration system. I'd suggest starting here for most pool owners because they don't stress your existing filtration system and typically provide the most thorough cleaning. They climb walls, scrub surfaces, and many models include smart navigation to ensure complete coverage.
Robotic cleaners work independently of your pool's circulation system, which means they won't clog your cartridge filters with fine debris. This is a significant advantage with your setup.
Suction Cleaners (Budget-Friendly)
These connect to your skimmer or dedicated suction line and use your pool pump's power. They're less expensive but will send all debris through your cartridge filters, requiring more frequent filter cleaning. For pools with heavy debris loads, this can become costly due to increased cartridge replacement.
Pressure Cleaners (Good for Large Debris)
These use return line pressure and typically include their own debris bag. They're excellent for pools with lots of leaves and larger debris, though they may miss fine particles. Your cartridge system would need adequate return pressure for optimal performance.
Making the Financial Case
Consider the time value: if manual vacuuming takes you an hour weekly (depending on your pool size and debris load), that could be 50+ hours annually. Even at modest hourly valuations of your time, an automatic cleaner often pays for itself quickly. Additionally, consistent cleaning helps maintain better water chemistry, potentially reducing chemical costs and extending the life of your filtration system.
What You'll Still Need to Do
Automatic cleaners don't eliminate all maintenance. You'll still need to empty skimmer baskets, maintain proper water chemistry, and clean the cleaner itself periodically. Think of it as shifting from active cleaning to supervisory maintenance - much less hands-on time, but not zero involvement.
For optimal results, you'll want to maintain your regular water chemistry testing schedule and ensure proper circulation times to support whatever cleaner you choose.
My Recommendation for Your Setup
Given your cartridge filter system and rectangular pool, I'd recommend starting with a quality robotic cleaner. The independent filtration means less stress on your existing system, and the thorough cleaning will likely improve your overall water quality. Many pool owners report that robotic cleaners actually extend cartridge filter life by removing debris before it reaches the main filtration system.
You can always supplement with manual cleaning for specific situations, but having the automatic option means consistent maintenance even during busy periods. The investment typically ranges from moderate to significant depending on features, but most owners consider it one of their best pool-related purchases.
