Does Lowe's Have Pool Vacuums? Complete Buying Guide 2024
Carol B.
First-time Pool Owner
Where to buy pool vacuums without getting ripped off by pool stores?
Looked at my pool this morning and decided I'm done paying someone else to clean it — just need to figure out if Lowe's has decent pool vacuums worth buying. Last week they tried to convince me I needed a $2,000 robotic cleaner when all I want is something decent to keep my pool clean without breaking the bank.
Does anyone know if big box stores like Lowe's actually carry pool vacuums? I'm hoping to find some options there since they usually have better prices than the specialty pool shops. I don't mind doing the research myself - just need to know what brands and price ranges to expect so I can make a smart purchase without some salesperson breathing down my neck.
Yes, Lowe's carries a variety of pool vacuums including manual, automatic, and robotic models both in-store and online. Their selection includes popular brands like Hayward, Pentair, and Dolphin with prices ranging from $30 for basic manual vacuums to $1,500+ for premium robotic cleaners.
Step-by-Step Guide to Shopping for Pool Vacuums at Lowe's
  1. Determine your pool type and size first. Measure your pool's dimensions and note whether you have vinyl, fiberglass, or concrete/plaster surfaces. This information is crucial because different vacuum types work better with specific pool materials and sizes.
  2. Decide on your budget range. Lowe's typically stocks manual pool vacuums starting around $30-60, automatic suction cleaners from $100-400, pressure-side cleaners from $200-600, and robotic cleaners from $500-1,500+.
  3. Check Lowe's online inventory before visiting the store. Visit lowes.com and search for "pool vacuum" to see current availability at your local store. You can filter results by price, brand, customer ratings, and pickup availability.
  4. Visit the pool supply section in-store. Pool vacuums are typically located in the seasonal/outdoor living section alongside pool chemicals and other maintenance equipment. This is usually most fully stocked from March through August.
  5. Compare the main vacuum types available. Lowe's typically carries manual vacuum heads and hoses (requiring you to do the work), automatic suction cleaners that connect to your skimmer, pressure-side cleaners that use return jets, and robotic cleaners with their own filtration systems.
  6. Read the packaging specifications carefully. Check that the vacuum is rated for your pool size, surface type, and filtration system. Pay attention to hose length requirements - you'll need enough hose to reach every corner of your pool.
  7. Ask about return policies and warranties. Pool equipment can be finicky, so understand Lowe's return policy (typically 90 days) and any manufacturer warranties that come with your chosen vacuum.
  8. Consider purchasing additional accessories. You may need pool brushes, leaf rakes, telescoping poles, or extra hose sections. Lowe's typically stocks these complementary items in the same section.
Types of Pool Vacuums You'll Find at Lowe's
Manual Pool Vacuums
Lowe's stocks basic manual vacuum heads from brands like Poolmaster and Swimline. These require a telescoping pole and dedicated vacuum hose that connects to your skimmer or vacuum port. Prices typically range from $25-80, making them the most budget-friendly option for smaller pools or spot cleaning.
Automatic Suction Cleaners
Popular models include the Hayward Navigator, Pentair Kreepy Krauly, and Zodiac Baracuda series. These connect to your pool's skimmer and use the existing filtration system's suction power. Expect to pay $150-400 for these models at Lowe's.
Pressure-Side Cleaners
Lowe's often carries Polaris and Pentair pressure-side models that use water pressure from your return jets to move around and collect debris in their own filter bags. These typically cost $300-600 and work well for pools with heavy debris loads. Note that most pressure-side cleaners require a dedicated return line or booster pump for proper operation, with booster pumps adding an additional $200-400 to your total investment.
Robotic Pool Cleaners
High-end options include Dolphin, Hayward SharkVac, and Pentair Warrior models. These self-contained units have their own motors, filtration, and programmable cleaning cycles. Prices at Lowe's range from $500-1,500+ depending on features.
What to Expect When Shopping at Lowe's
Lowe's pool equipment selection varies significantly by season and location. Stores in warmer climates maintain year-round pool sections, while northern locations may have limited winter inventory. The best selection is typically available from April through July.
Staff knowledge can be hit-or-miss regarding pool equipment specifics, so it's helpful to research models online first. However, Lowe's does offer installation services for some pool equipment through their professional services program.
Comparing Lowe's to Other Pool Vacuum Sources
While Lowe's offers convenience and competitive pricing, dedicated pool supply stores may have broader selections and more knowledgeable staff. Online retailers often have better prices but lack the ability to see products in person. Lowe's strikes a good middle ground with their price-match policy and easy returns.
Money-Saving Tips for Pool Vacuum Shopping at Lowe's
Important note: Before purchasing any pool vacuum, ensure your pool's circulation system is working properly and your water chemistry is balanced. Proper water chemistry affects vacuum performance and longevity, so establish balanced chemical levels first to ensure optimal vacuum selection and operation.
pool measurements budget planning smartphone or computer for research
Tags: #pool vacuum #lowes #pool cleaning #equipment shopping #pool maintenance
